void loop , repeatedly not work!
run repeatedly not work!
i want this wokr repeatedly scan RFID Tag but this still work only one time after i scan the Rfid tag :confused: :confused: :confused: :confused:
any problem in code????
code here!
#include <SPI.h>//include the SPI bus library
#include <MFRC522.h>//include the RFID reader library
#define SS_PIN 10  //slave select pin
#define RST_PIN 5  //reset pin
MFRC522 mfrc522(SS_PIN, RST_PIN);        // instatiate a MFRC522 reader object.
MFRC522::MIFARE_Key key;//create a MIFARE_Key struct named 'key', which will hold the card information
        Serial.begin(9600);        // Initialize serial communications with the PC
        SPI.begin();               // Init SPI bus
        mfrc522.PCD_Init();        // Init MFRC522 card (in case you wonder what PCD means: proximity coupling device)
        Serial.println("Scan a MIFARE Classic card");
Where's the rest of your code? The above is incomplete (no closing brace for setup()) and missing the loop:
}//loop
Full complete code is here!
        // Prepare the security key for the read and write functions - all six key bytes are set to 0xFF at chip delivery from the factory.
        // Since the cards in the kit are new and the keys were never defined, they are 0xFF
        // if we had a card that was programmed by someone else, we would need to know the key to be able to access it. This key would then need to be stored in 'key' instead.
        for (byte i = 0; i < 6; i++) {
                key.keyByte[i] = 0xFF;//keyByte is defined in the "MIFARE_Key" 'struct' definition in the .h file of the library
int block=2;//this is the block number we will write into and then read. Do not write into 'sector trailer' block, since this can make the block unusable.
byte readbackblock[18];//This array is used for reading out a block. The MIFARE_Read method requires a buffer that is at least 18 bytes to hold the 16 bytes of a block.
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial()) {
    return;
  Serial.println(F("**Card Detected:**"));
        // Among other things, the PICC_ReadCardSerial() method reads the UID and the SAK (Select acknowledge) into the mfrc522.uid struct, which is also instantiated
        // during this process.
        // The UID is needed during the authentication process
        	//The Uid struct:
	        //typedef struct {
		//byte		size;			// Number of bytes in the UID. 4, 7 or 10.
		//byte		uidByte[10];            //the user ID in 10 bytes.
		//byte		sak;			// The SAK (Select acknowledge) byte returned from the PICC after successful selection.
	        //} Uid;
         Serial.println("card selected");
         readBlock(block, readbackblock);//read the block back
         Serial.print("STUDENT NAME: ");
         for (int j=0 ; j<16 ; j++)//print the block contents
           Serial.write (readbackblock[j]);//Serial.write() transmits the ASCII numbers as human readable characters to serial monitor
         Serial.println("");
          return ;
       mfrc522.PICC_DumpDetailsToSerial(&(mfrc522.uid)); //dump some details about the card
         return ;
int writeBlock(int blockNumber, byte arrayAddress[])
  //this makes sure that we only write into data blocks. Every 4th block is a trailer block for the access/security info.
  int largestModulo4Number=blockNumber/4*4;
  int trailerBlock=largestModulo4Number+3;//determine trailer block for the sector
  if (blockNumber > 2 && (blockNumber+1)%4 == 0){Serial.print(blockNumber);Serial.println(" is a trailer block:");return 2;}//block number is a trailer block (modulo 4); quit and send error code 2
  Serial.println(" is a data block:");
  byte status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(mfrc522.uid));
  //byte PCD_Authenticate(byte command, byte blockAddr, MIFARE_Key *key, Uid *uid);
  //this method is used to authenticate a certain block for writing or reading
  //command: See enumerations above -> PICC_CMD_MF_AUTH_KEY_A  = 0x60 (=1100000),    // this command performs authentication with Key A
  //blockAddr is the number of the block from 0 to 15.
  //MIFARE_Key *key is a pointer to the MIFARE_Key struct defined above, this struct needs to be defined for each block. New cards have all A/B= FF FF FF FF FF FF
  //Uid *uid is a pointer to the UID struct that contains the user ID of the card.
  if (status != MFRC522::STATUS_OK) {
         Serial.print("PCD_Authenticate() failed: ");
         Serial.println(mfrc522.GetStatusCodeName(status));
         return 3;//return "3" as error message
  //it appears the authentication needs to be made before every block read/write within a specific sector.
  //If a different sector is being authenticated access to the previous one is lost.
  status = mfrc522.MIFARE_Write(blockNumber, arrayAddress, 16);//valueBlockA is the block number, MIFARE_Write(block number (0-15), byte array containing 16 values, number of bytes in block (=16))
  //status = mfrc522.MIFARE_Write(9, value1Block, 16);
           Serial.print("MIFARE_Write() failed: ");
           return ;//return "4" as error message
  Serial.println("block was written");
int readBlock(int blockNumber, byte arrayAddress[])
  /*****************************************authentication of the desired block for access***********************************************************/
         Serial.print("PCD_Authenticate() failed (read): ");
         return ;//return "3" as error message
  /*****************************************reading a block***********************************************************/
  byte buffersize = 18;//we need to define a variable with the read buffer size, since the MIFARE_Read method below needs a pointer to the variable that contains the size...
  status = mfrc522.MIFARE_Read(blockNumber, arrayAddress, &buffersize);//&buffersize is a pointer to the buffersize variable; MIFARE_Read requires a pointer instead of just a number
          Serial.print("MIFARE_read() failed: ");
  Serial.println("block was read");
But run repeatedly not work!
That will never be called, the loop exits on the line before.
Where does "arrayAddress" come from?
-jim lee
Don’t use return like you are doing. Return is for subroutines to return a value. The way you are using it, is causing you to drop out of the loop() function.
Look upin the Reference section, how to do an if statement.
//the problem is :not scan another Rfid card after scan a card and still showing 1st card not another!
rajuji:
... any problem in code?
Yes.
