Full code here:
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
// Set these to run example.
#define FIREBASE_HOST "*****************"
#define FIREBASE_AUTH "********************************"
#define WIFI_SSID "******"
#define WIFI_PASSWORD "********"
#define ENA D7 // ENABLE A
#define INP1 D1 // FORWARD A
#define INP2 D3 // REVERSE A
#define INP3 D4 // FORWARD B
#define INP4 D5 // REVERSE B
#define ENB D8 // ENABLE B
#define t 5 // time interval of data rate
int For = 0;
int Rev = 0;
int Lef = 0;
int Rig = 0;
pinMode(ENA, OUTPUT);
pinMode(INP1, OUTPUT);
pinMode(INP2, OUTPUT);
pinMode(INP3, OUTPUT);
pinMode(INP4, OUTPUT);
pinMode(ENB, OUTPUT);
// connect to wifi.
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("connecting");
Serial.print(".");
Serial.print("connected: ");
//Firebase Start
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
// update value
Firebase.setFloat("Wheelchair_Console/number", 1);
// handle error
if (Firebase.failed()) {
Serial.print("setting /number failed:");
Serial.println(Firebase.error());
return;
delay(t);
int n = 0;
Serial.print("Forward: ");
Serial.println(For = Firebase.getString("control/for").toInt());
Serial.print("Reverse: ");
Serial.println(Rev = Firebase.getString("control/backward").toInt());
Serial.print("Left: ");
Serial.println(Lef = Firebase.getString("control/lef").toInt());
Serial.print("Right: ");
Serial.println(Rig = Firebase.getString("control/right").toInt());
if (For == 1) {
forward1();
if (Rev == 1) {
reverse1();
if (Rig == 1) {
right();
else if (Lef == 1) {
turnleft();
else still();
delay(t);
void still() {
digitalWrite(ENA, LOW);
digitalWrite(INP1, LOW);
digitalWrite(INP2, LOW);
digitalWrite(INP3, LOW);
digitalWrite(INP4, LOW);
digitalWrite(ENB, LOW);
void reverse1() {
digitalWrite(ENA, HIGH);
digitalWrite(INP2, HIGH);
digitalWrite(INP4, HIGH);
digitalWrite(ENB, HIGH);
void turnleft() {
digitalWrite(INP1, HIGH);
void right() {
digitalWrite(INP3, HIGH);
void forward1() {
What happens here if For == 1 (and Rev, Rig and Lef are not)?
More importantly: what happens no matter what the value is?
if (For == 1) {
forward1();
if (Rev == 1) {
reverse1();
if (Rig == 1) {
right();
turnleft();
else still();
Adding a couple of elses will fix it.
