Void Rainbow on Scrolling Text
#define CLR_WHITE 8
#define CLR_RED 2
const int led_row =5;
const int led_col=24;
int led_count= led_row *led_col;
Adafruit_NeoPixel strip = Adafruit_NeoPixel (led_count,2,NEO_GRB + NEO_KHZ800);
byte value_r=255;
byte value_g=0;
byte value_b=0;
byte color_in_row[12];
int index_animasi=0;
byte color_data[9][3]{
  {0,255,255},
  {255,255,0},
  {255,0,0},
  {0,255,0},
  {0,0,255},
  {0,255,255},
  {255,0,0},
  {0,0,255},
  {255,255,255}
const byte font_wave[] PROGMEM ={
        0x1C, 0x0A, 0x09, 0x0A, 0x1C,0x00,      // Code for char A
        0x1F, 0x15, 0x15, 0x15, 0x0A,0x00,      // Code for char B
        0x1F, 0x11, 0x11, 0x11, 0x11,0x00,      // Code for char C
        0x1F, 0x11, 0x11, 0x11, 0x0E,0x00 ,     // Code for char D
        0x1F, 0x15, 0x15, 0x15, 0x15,0x00,      // Code for char E
        0x1F, 0x05, 0x05, 0x05, 0x05,0x00,      // Code for char F
        0x1F, 0x11, 0x15, 0x15, 0x1D,0x00,      // Code for char G
        0x1F, 0x04, 0x04, 0x04, 0x1F,0x00,      // Code for char H
        0x11, 0x11, 0x1F, 0x11, 0x11,0x00,      // Code for char I
        0x08, 0x10, 0x10, 0x10, 0x0F,0x00,      // Code for char J
        0x1F, 0x04, 0x0E, 0x1B, 0x11,0x00,      // Code for char K
        0x1F, 0x10, 0x10, 0x10, 0x10,0x00,      // Code for char L
        0x1F, 0x02, 0x04, 0x02, 0x1F,0x00,      // Code for char M
        0x1F, 0x02, 0x04, 0x08, 0x1F,0x00,      // Code for char N
        0x0E, 0x11, 0x11, 0x11, 0x0E,0x00,      // Code for char O
        0x1F, 0x05, 0x05, 0x05, 0x07,0x00,      // Code for char P
        0x0E, 0x11, 0x15, 0x09, 0x16,0x00,      // Code for char Q
        0x1F, 0x05, 0x0D, 0x15, 0x02,0x00,      // Code for char R
        0x12, 0x15, 0x15, 0x15, 0x09,0x00,      // Code for char S
        0x01, 0x01, 0x1F, 0x01, 0x01,0x00,      // Code for char T
        0x0F, 0x10, 0x10, 0x10, 0x0F,0x00,      // Code for char U
        0x07, 0x08, 0x10, 0x08, 0x07,0x00,      // Code for char V
        0x1F, 0x08, 0x04, 0x08, 0x1F,0x00,      // Code for char W
        0x11, 0x0A, 0x04, 0x0A, 0x11,0x00,      // Code for char X
        0x01, 0x02, 0x1C, 0x02, 0x01,0x00,      // Code for char Y
        0x11, 0x19, 0x15, 0x13, 0x11,0x00,      // Code for char Z
const byte module_max=10;
byte data_col[module_max*12];
  Serial.println("Belajar Strobo #Eps.02 ShareAnimasi 001");
  strip.begin();
  strip.show();
  String s="HINO";
  int c=0;
    for (byte a=0;a<s.length();a++){
    int index_char=s[a]-65;
      for(byte i=0;i<6;i++){
      byte b=pgm_read_byte(&font_wave[index_char*6+i]);
      data_col[c]=b;
      c++;
        if (b==0){
        else{
  for (int z=0;z<s.length()*6+24;z++){
  pixel_shift();
  //pixel_print();
  pixel_show();
  //animation_text();
void pixel_show(){
  for(byte c=0;c<led_col;c++){
      for (int r=0;r<5;r++){
      byte b=bitRead(data_col[c+21],r);
      int index_led=led_from_pixel(4-r,c);
        if (b==1){
              strip.setPixelColor(index_led, Wheel(255));
        else{
          strip.setPixelColor(index_led,strip.Color(0,0,0));
      Serial.print(b);
      Serial.print(" ");
  strip.show();
void pixel_print(){
  int j=4;
  for(int r=0;r<5;r++){
      for (int c=0;c<led_col;c++){
      byte b=bitRead(data_col[c+j*6],r);
        if (b==1){
              strip.setPixelColor(index_led, Wheel((r+c) & 255));
        else{
      Serial.print(b);
      Serial.print(" ");
  strip.show();
void pixel_shift(){
  for (int c=60;c>0;c--){
    data_col[c]=data_col[c-1];
    data_col[c-1]=0;
int led_from_pixel(byte row,byte col){
  int a=0;
  if (row%2==0){
    a=(row*led_col)+col;
  else{
    a=((row+1)*led_col)-1-col;
  return a;
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Hi guys can somebody help me with the programming code of scrolling text with the variation of rainbow color
