Voids in loop using "if" Function
Should/Could this work?
 ExampleVoid();//I know that this should work, But will only call it once
 if (Var1==Var2){
  ExampleVoid();
void ExampleVoid()
  DoCoolStuff;
Want to reduce loop time by only using code when needed.
It could work if you were to auto format your code to see that there is a missing thingy.
"void" means "nothing", "empty", it's a keyword used to indicate that a function doesn't return any values. The word you're looking for is "function", ExampleVoid is a function without any parameters and a "void" return type.
You're missing a '}' at the end of the "setup" function, but other that that, it should work, why don't you try it?
Pieter
Because I dumb dumb. Got a "Not declared" error for the specific function I wanted to call and could not seem to track down the error. eventually found I had not closed off the previous function.
