volatile boolean variable changing between setup and ISR
Remove both lines below from your interrupt routine. Interrupts are already turned off within an interrupt routine.
  noInterrupts();        // Turn OFF all interrupts during ISR so  flag  is not changed
   volatile boolean flag;
Also remove this line from the end of the ISR, or the ISR itself could be interrupted by another.
   interrupts();         // Turn ON all interrupts
