Volatile variable value do not change in ISR
Hi!
I’m using ATtiny13a and in my project I wanted to implement sleeping and waking up using watchdog timer. However the variable I declared as volatile does not hold its value in ISR so I can not wait longer than 8 seconds. Is there any points I miss? Any help appreciated.
#include <avr/interrupt.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
#define BUZZER_PIN PB1
volatile uint8_t count = 0;
ISR(WDT_vect)
  count++;
  if (count > 1)
    PORTB ^= _BV(BUZZER_PIN); // Toggle Port
  // initialize the digital pin as an output.
  pinMode(BUZZER_PIN, OUTPUT);
  digitalWrite(BUZZER_PIN, LOW);
  wdt_enable(WDTO_8S); //Set watchdog timer to 8 seconds
  WDTCR |= (1 << WDTIE); // Enable watchdog timer interrupts
  sei();                 // Enable global interrupts
  // Use the Power Down sleep mode
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  for (;;)
    sleep_mode(); // go to sleep and wait for interrupt...
// the loop routine runs over and over again forever:
ISR(WDT_vect)
  count++;
  if (count > 1)
Shouldn't you set 'count' back to 0 when toggling the buzzer pin? Otherwise, it will just keep counting and will always be "> 1" on every interrupt.
Note: There is a special feature of the PIN (Port INput) register that will toggle an output pin if you write 1 to it:
    PINB = _BV(BUZZER_PIN); // Toggle the buzzer pin
johnwasser:
ISR(WDT_vect)
 count++;
 if (count > 1)
Yes, you are right. However, the point here is it never goes into the if statement without increasing count variable to exceed the limit in the first place.
ISR(WDT_vect)
 count++;
 if (count > 1)
Are you sure ISR(WDT_vect) is called at all?
What happens when you change that to
ISR(WDT_vect)
Erik_Baas:
ISR(WDT_vect)
Yes, it does. Even if I change count++ to count+=2 the pin toggles.
Is it possible the watchdog timer does not only call the ISR, but also resets the ATTiny? I know it can do that, but I don't know how... Could you add a Serial.println("test") or something like that to void setup() to check that?
And how about Serial.println(count) once every second in void loop() ?
Have you tried clearing the count as I suggested?
ISR(WDT_vect)
  count++;
  if (count > 1)
    count = 0;  //------------  ADD THIS LINE -----------------
Erik_Baas:
Is it possible the watchdog timer does not only call the ISR, but also resets the ATTiny? I know it can do that, but I don’t know how… Could you add a Serial.println("test") or something like that to void setup() to check that?
Thanks a lot for this. Apparently wde_enable(WDTO_8S) was causing the watchdog to be in interrupt and reset mode and causing attiny to reset after each interrupt. I have used
WDTCR = (1 << WDTIE) | (1 << WDP3) | (0 << WDP2) | (0 << WDP1) | (1 << WDP0); //8 Seconds
instead of wde_enable(WDTO_8S) and it works now.
