Volt meter displaying on 7 segment LED display
Best forum watchers,
I’ve been busy with a voltmeter project lately and I got stuck at some point. I looked at a video of robojax where he makes a voltmeter that is able to read higher voltages than just the 5 volts of the Arduino. when I measure the voltage I want to classify different cases to lower and higher values of voltages. for example
if (voltage_sensed >0) {
int x_value = 1;
else if (voltage_sensed >30) {
int x_value = 2;
and so on
for x_value i want to light up the 7 segments LED display. so i make a switch statement where i say that a certain case should appear when it has the integer number of x_value
switch(x_value) {
case 1:
zero(); // is the funtion that represents a 0 on the 7 segment led display
case 2:
one();
but when I do this is doesn’t execute the case that I want. But when I print the x_value on my Serial monitor is does appear to have an integer value of for example 0 or 1. It just doesn’t execute. I will post the code below here.
thanks in advance for helping me out
Volt_meter_v5.ino (4.6 KB)
Please post your code, in code tags.
Your problem is with scoping. Every time you declare 'int x_value' you declare a new variable 'x_value' within the corresponding code block. They are not all the same!
Leave the 'int x_value' at the top of your sketch (global declaration) and remove the 'int' from in front of all the assignments you make in other parts of the code.
Scope
isn't >0 true before > 30?
