Voltage and Current measurment using arduino
I have been working on a project (solar panel analyzer) and thing is that measuring voltage and current through Arduino using current and voltage sensors. we also have to design a resistive load for IV curve plotting. Someone please help me with this
Hello
Take some time and make a research to Texas Instruments INA219 family.
Hi, @hashh
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
This will help with advice on how to present your code and problems.
Have you Googled;
arduino resistive load
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
I have read about this but came to know this sensor is good for small current values, but in my case i have current upto 10A with 50V max
Hello
Did you check the Texas homepage for "high voltage" sensors" too?
let me go through it
A resistive load can only give you one point in the curve, an active load is what you need, perhaps a constant current sink with a high power rating. Program its current at a range of different levels and read the sensors, plot the points.
Doing the same designed a variable resistive load being switched using MOSfets
That might not be quite the same thing as an analog current sink. You say "switched" and that might not provide really accurate results because PWM is still drawing full amps during conduction.
Or, are you talking about a switched resistor bank?
Switched resistor bank
Mark is right, you can't plot a VI curve with a resistive load because the current changes with voltage.
will you please provide me with some example for this?
Here are some examples:
https://www.google.com/search?client=firefox-b-d&q=programmable+current+sink
Thanks you aarg can such sinks be designed for 50V,10A ?/
Yes they can. You could design one to test a railroad locomotive if you wanted...
One last thing that still remains! i am facing real difficulty is with the use of current and voltage sensors guide through this i will be highly obliged
That is really hard without knowing what sensors and what difficulties you have. What is your level of electronics expertise?
Using ACS712 current sensor while using simple voltage divider circuit for voltage measurement. I managed to calibrate both of them with my arduino UNO individually but when i combine the sensors along with my resistive load bank i am getting wrong values for voltage
Again, extremely light on details. Please provide complete, detailed information about your project, or the feedback that you get won't be very helpful.
Also
Do you have Battery Bank + Batter Charger connected at the output of the Solar Panel? If so, how much is the Battrey voltage at float lavel?
