voltage AC sensor range(150-300) or more .
vloltage DC sensor range (220).
current AC sensor range measurment high current.
current dc sensor range measurment high current.
and thanks
of you have more than one name i will be greatful .
power factor sensor .
can i just post a code to meausment the power factor or i need the zero crossing detector.
reading DC can simply be done with a resistor devider.(google)
choose 2 resistors which devide the voltage such that over the 2nd resistor you will have a voltage of 0-5v. also make sure that your impedance is high enough not to draw much current trough the resistors burning hem or pulling your supply voltage down rendering the measurement ineffective.
standard voltage sensors for arduino do exactly this. 2 resistors chosen so that you can measure up to 25vdc. if going over 25v the output will be >5v blowing your Analog input. choose different resistors solves this puzzle for your specific power supply.
