I bought the mcp4725 for I understand that with it is possible to take out a certain DC, for example 2.5V.
I can't get it to work.
I don't know if it's a problem of how to connect to Arduino (Uno) or programming.
I use the "trianglewave" example of Adafruit Library MCP4725. And then I connect the mcp4725 to Arduino Uno :
GND = GND
VDD -> 5V
A0 -> free
SDA -> A4
SCL -> A5
OUT -> Tester (I don't have an oscilloscope)
But I always got a fixed voltage number. I couldn't do it even by changing the program, e.g.:
Run this i2c scanner program from the ide (File>Examples>Wire>i2c_scanner) and confirm the address
// i2c_scanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// https://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
// As version 4, but address scans now to 127.
// A sensor seems to use address 120.
// Version 6, November 27, 2015.
// Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
Wire.begin();
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
int nDevices = 0;
Serial.println("Scanning...");
for (byte address = 1; address < 127; ++address) {
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
byte error = Wire.endTransmission();
if (error == 0) {
Serial.print("I2C device found at address 0x");
if (address < 16) {
Serial.print("0");
Serial.print(address, HEX);
Serial.println(" !");
++nDevices;
} else if (error == 4) {
Serial.print("Unknown error at address 0x");
if (address < 16) {
Serial.print("0");
Serial.println(address, HEX);
if (nDevices == 0) {
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // Wait 5 seconds for next scan
