I am working with an Arduino 101 and connected it to a wheastone bridge with 3 resistors (330 ohms) and 1 strain gauge. I have given an input voltage of 5V to the bridge, I measured the output voltage on a multimeter and through the Arduino and there seems to be a large difference in these values. When I change the input voltage to 3.3 V, the voltage measured form the multimeter and Arduino are equal. Could anyone please explain why this is happening?
Voltage between point 8 and GND on multimeter = 2.43V
Voltage between point 8 and GND on Arduino = 3.69V
Voltage between point 7 and GND on multimeter = 2.51V
Voltage between point 7 and GND on Arduino = 3.80V
Voltage between points 7 and 8 on multimeter = 86.2 mV
Values when input voltage is 3.3V:
Voltage between point 8 and GND on multimeter = 1.59V
Voltage between point 8 and GND on Arduino = 1.60V
Voltage between point 7 and GND on multimeter = 1.64V
Voltage between point 7 and GND on Arduino = 1.65V
Voltage between points 7 and 8 on multimeter = 55.5 mV
These are the specifications (attached) I could find regarding the strain gauges on the website:
Mini DC-DC 12-24V To 5V 3A Step Down Power Supply Module Voltage Buck Converter Adjustable Efficiency 97.5%
Input Voltage:DC 4.5-24V
Output Voltage:integration adjustable and fixed output,back side can choose fiexd output voltage
Adjustable Range:0.8-17V,fixed voltage (1.8V 2.5V 3.3V 5V 9V 12V)
Output Current:3A (max),actual testing input 12V output 1.5A
What does your code assume is the reference voltage for the ADC? I believe it's fixed at 3.3V for the 101. Your results look like what you'd get if you assume it changes to 5V because your circuit is run from 5V.
