They say the memory is the second thing to go. I was tooling around the web last night, looking for a new set of motors and a compatible H bridge. In my "travels" I saw a nifty little breakout board that took in either 24 or 12 volts (can't exactly remember) and split it out into various terminals, each with a different output voltage, iirc 2.4, 3.3, 5 and 12 volts. I thought I saved it to look at later, now I can't find it. Has anyone seen anything like this, maybe could point me in the right direction? I've tried searching under the following terms to no avail: "voltage divider", "voltage regulator breakout board", "DC voltage distribution board" and a couple others using much the same words, rearranged.
regards, Richard
