voltage dividers
Hi. i am just wundering? what does the EX) mean on this: https://dl-web.dropbox.com/get/Public/voltage%20dividers.jpg?w=7c4fc0ba And the vin and vout? thank you for you time:)
The link you provide is "wrong". I need to "log in" and give the code - 403. Can not see what you trying to show us.
Sorry.
thank for pointing that out:) do you know any sites i can host a image?
here.
mrdove500:
EXample
Ex is possibly short hand for example. This is an explanation of voltage dividers. Vin is the input voltage Vout is the output voltage to which Vin must be converted into. In the example Vin is 5V and it is converted into Vout 2.5V.
thank you all! so much i will mean it:)
mrdove500:
I might try this.
By the way. Good try. The file is 1.4 Mbytes. It is possible to reduce the file size using this program call IrfanView. Here the site : http://www.irfanview.com/. I use this program when I plan to send big files. Example : Picture taken from a digital camera. Or scan documents / pictures. I am new at that software, so, I only use to reduce my files and send it on-line.
Beside, I have a dial-up. :.
