Voltage drop down with sim800L module
I am using a gsm module sim800 to do http post requests and after 2h the module stops working because of under voltage warning.
The module is this one http://www.ebay.co.uk/itm/SIM800L-GPRS-GSM-Module-Board-Quadband-QUAD-BAND-Antenna-for-MCU-Arduino-/321992759287
I am making a lot of HTTP POST requests in a row every 10 min with 5 sec interval between each request. I am using the Adafruit FONA library.
The module is powered on the 5V of an arduino mega.
It works perfectly but after around 2h it suddenly stops working.
How could I power the module better in order that it resists to the 2A current peak over time?
Thanks
GSM modules can take lots of current, you cannot power from the board's 5V regulator. Use an external
2A+ supply - then it'll be able to cope.
Thanks for your reply. Could you give me an example of power supply I should use then ?
One with an output current rating of 2 or more amps? No point recommending a product if
we don't know which continent you are on even!
