voltage getting down with L298N and stepper
hi
am trying to build some 3d printer using arduino uno and mega,an extruder,4 nema 17 ,4 L298N but
i have lost 3 bridged till now i can’t figure why
so i constructed som voltage regulator using some resistores and LM317T
and using this code on the mega :
// Arduino stepper motor control code
#include <Stepper.h> // Include the header file
// change this to the number of steps on your motor
#define stepsPerRevolution 60
// create an instance of the stepper class using the steps and pins
Stepper stepperX(stepsPerRevolution, 42, 44, 46, 48);
Stepper stepperY(stepsPerRevolution, 22, 24, 26, 28);
Stepper stepperF(stepsPerRevolution, 32, 34, 36, 38);
Stepper stepperZ(stepsPerRevolution, 23, 25,27, 29);
int val = 0;
  stepperX.setSpeed(350);
  stepperY.setSpeed(350);
  stepperZ.setSpeed(250);
  stepperF.setSpeed(200);
  if (Serial.available()>0)
    val = Serial.parseInt();
// stepperX.step(val);delay(500);
//stepperZ.step(val);delay(500);
stepperY.step(val); delay(500);
//   stepperF.step(val); delay(500);
    Serial.println(val); //for debugging
i get voltage going down when sending step and still down untill i press reset button
is it normal?
in the other hend the motor stop turning well when voltage is under 6v and the bridge get hot
can i get more explanation why that happen
Post a link to the stepper motor.
The L298 is a brushed DC motor driver, and is not a suitable for most modern low-impedance stepper motors.
Leo..
You should find stepper motor basics helpful.
Jones on steppers is more advanced.
there is motor model
https://www.hotmcu.com/nema17-bipolar-48mm-stepper-motor-p-183.html
1.25ohm coils, and 2.5A max coil current.
That definately needs a beefy stepper driver.
An L298 is totally unsuitable.
You also need a 12volt supply (or >= 24volt supply if you need speed) with the right current rating for four motors.
Leo..
