Voltage indicator with photosensor
Hello
I am creating an Arduino sketch that scrolls the sentence "The voltage is > 2.5V" to the left on the first row of the LCD if the voltage level at pin A5 is greater than 2.5 volts. If the voltage level at pin A5 is less than 2.5 volts, the sentence "The voltage is 2.5V" will scroll to the right on the LCD's second row.
Although I am almost done I don't know what is the issue
  • the first loop stops if it is below 2.5 but if it above it doesn't stop
  • How to break the loop if I want to transition between them
// C++ code
#include <LiquidCrystal.h>
const int rs=8, e=9, d4=10, d5=11, d6=12, d7=13;
LiquidCrystal lcd(rs,e,d4,d5,d6,d7);
int ls; //photoresistor
float voltage;
  lcd.begin(16, 2);
  ls = analogRead(A5);
  voltage = ls * (5.0 / 679.0); //converting to voltage
  Serial.println(voltage); //print voltage
  int i=0;
  if (voltage < 2.5) {
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("The voltage is < 2.5V");
    while (i < 1) {
      // scroll one position right:
      lcd.scrollDisplayRight();
      delay(100);
      if (voltage > 2.5){
  else {
    lcd.clear();
    lcd.print("The voltage is > 2.5V");
    while (i < 1) {
      // scroll one position left:
      lcd.scrollDisplayLeft();
      delay(100);
      if (voltage < 2.5){
Hello
What is the design goal to use a while() in side the loop?
When you’re happy this is working the way you want it to, move the animation out into a function and get rid of the delay() calls.
Then your program can do something alongside the animated text!
Once you are inside the while loop, voltage never changes. You will have to read the analog input again and do the calculation.
scrolling text in the LCD to the left and right side respectively
Do you mean to make this a function?
and if I removed delay it won't move
Do you mean something like this?
Yes, that would be better.
What is the use of the variable i in while(i < 1)? It never changes as far as I can see.
i is for the loop
as long i<1 the loop will not stop till the value of photoresistor change
Would it? :face_with_hand_over_mouth:
How about
float voltage()
  int ls = analogRead(A5);
  return ls * (5.0 / 679.0);
Then you can say
        if (voltage() > 2.5){
but, as @sterretje pointed out, i never changes. What's the point of a variable that never varies?
You might as well say
while(true) ...
The photoresistor can change, sure, but the variable voltage will not, right now, as also pointed out.
thank you this works but for some reason the first if condition stops scrolling after once but the second one doesn't
updated code:
// C++ code
float voltage()
  lcd.begin(16, 2);
  Serial.println(voltage()); //print voltage
  if (voltage() < 2.5) {
    lcd.clear();
    while (true) {
      delay(100);
  else {
    lcd.clear();
    while (true) {
      delay(100);
      if (voltage() < 2.5){
Try it using a real Arduino and real components and let us know if the real circuit has the same problem.
Will let you guys know next week then
