Voltage input on digital pin (Arduino Uno)
Hello all :slight_smile:
What is the lower limit of voltage, the Arduino Uno will register on one of the digital pins?
For example, a curcuit is connected trough Arduino 5V and GND and have a output at only 0,5 volt. Will the digital input pin register that?
Thanks :slight_smile:
Tortun:
… 0,5 volt. Will the digital input pin register that?
As a LOW, yes.
I wouldn’t expect anything < 3V to be a consistently reliable “HIGH”.
So if I go below 3V on a digital pin, the Arduino Uno would not register it as HIGH.
Thank you :smiley:
Tortun: Hello all :)
Those values are best defined and explained in the Atmel ATmega329p datasheet along with all the other electrical specifications for the chip.
Lefty
Tortun: So if I go below 3V on a digital pin, the Arduino Uno would not register it as HIGH. Thank you :D
Well, I didn't "say" that, but you asked about "0.5V" In fact there's a point at which a voltage "must be" a HIGH and a similar point where some voltage "must be" a LOW, but there's a window of uncertainty between the two, a sort of no-man's land which should be avoided.
retrolefty: Those values are best defined and explained in the Atmel ATmega329p datasheet along with all the other electrical specifications for the chip.
Lefty
Unfortunately, that didn't help me :~
[quote author=Runaway Pancake link=topic=105590.msg792294#msg792294 date=1336852918] Well, I didn't "say" that, but you asked about "0.5V" In fact there's a point at which a voltage "must be" a HIGH and a similar point where some voltage "must be" a LOW, but there's a window of uncertainty between the two, a sort of no-man's land which should be avoided.
[/quote] What voltage is that between? The uncertainty about "HIGH" and "LOW". If you should say a voltage, were it would not anymore register a value as "HIGH" or the highest voltage you can think off, were it not at all would read it as "HIGH". (at least theoretically?) Sorry... But I really need some sort of number, since I have made an error with an operational amplifier... Hope there is some kind of possible answer :(
It's all there in the data sheet. In what way didn't it help you?
For an input to be seen as a logic low it must be below 0.3 * Vcc so at 5V Vcc this is below 1.5V
For an input to be seen as a logic high it must be above 0.6 * Vcc so at 5V Vcc this is above 3V
