Voltage issue
Hello, I'm using an arduino YUN with a grove shield and a blue led on PIN 2. Something very easy.
I tried several ways to power the arduino YUN, using the micro USB: - USB of 2 different computers - 2 different 5V power supplies : 1A and 2A
This is my code :
 digitalWrite(2, HIGH);
I get the same result : - The blue led and the shield power led randomly blinks like the the voltage falls down - sometimes, the sketch restarts
I want to drive led strips but I can't if the voltage is not stable.
Do you have any idea ? Thanks a lots
Best regards Frédéric
Set the pin as an output.
 pinMode(2, OUTPUT);
If you don't set the pin as an output, it is assumed to be an input. Calling digitalWrite() to set an input high results in turning on the internal pullup resistor. This will allow some current to flow to the LED, but not nearly enough to properly light it up.
