Is there a pre-made voltage output panel anywhere I can buy, with banana jacks, posts or anything else? I like to make something to use at all my workstations, and don't really want to take a trip to the garage to cut, drill, make mistakes. If I can find some cheap pre-fabricated panels that would be great.
There are nice possibiities. I have used THIS one on old ATX power supplies.
A make-it-your-own version is available from Sparkfun HERE..
Thank you, it will get the job done. Yes salvage computer power supplies they're the best.
DocStein99:
They have been well "burned in" Although it is a good idea to blow the dust out of them and check for bulging capacitors - those things can be dangerous (I had a cap blow in an old computer a while back and besides taking out the disk drive, CD drive, video card and the motherboard when it went, it vanished (mostly) leaving only "stuff" around inside the case and a couple of burned leads sticking up. :o
Saw something similar a long time ago, new monitor got installed (here in UK) but the
voltage selector was left at 110V, not changed to 240V. After a couple of hours the big cap
in its power supply exploded and sprayed the inside with aluminium and electrolyte.
