Voltage range for 6 V rated DC motor
This is the motor that i plan to use:
34:1 Metal Gearmotor 25Dx52L mm LP 6V with 48 CPR Encoder
But i do not have a voltage regulator for 6 V, so i'm wondering what if i were to supply a higher voltage to the motors? Would be they damaged? I could supply 5 V to it but then i think the performance of the motor will be less. There is no mention of the voltage operating range for that motor.
DryRun:
Pololu - 34:1 Metal Gearmotor 25Dx64L mm LP 6V with 48 CPR Encoder (No End Cap)
There is no mention because they want you to use one of their motor driver boards, which have a large range of input voltages. Are you going to use a driver board, or do it all yourself?
Paul
Paul_KD7HB:
Paul
I'm planning to use their TB6612FNG Dual Motor Driver Carrier
Will this motor driver automatically regulate the voltage to the motor to 6 V?
DryRun:
Pololu - TB6612FNG Dual Motor Driver Carrier
Probably not, but it will regulate the current to the motor, which is what causes the motor heat. So, the correct motor driver is necessary.
Paul
