this is due to integer division in BatVoltage (integer division truncates,
Change it to float to solve it
float batVolt(int senzorPin, float r1, float r2) {
int sensorValue = analogRead(senzorPin);
//Calc 1
float voltage = sensorValue * (5.0 / 1023.0);
//Calc 2
voltage = voltage / (r2 / (r1 + r2));
return voltage;
or If you want to do it with integer values for r1 and r2 you need to rewrite the formula
float batVolt(int senzorPin, int r1, int r2) {
//Calc 1
float voltage = sensorValue * (5.0 / 1023.0); // to speed up you could replace this with a constant 0.00488 something float division take a lot of time
//Calc 2
voltage = voltage * (r1 + r2) / r2;
return voltage;
Note this can be written into in short
return ((analogRead(senzorPin) * 0.004887586) * (r1 + r2)) / r2;
The () are needed to force float math otherwise (r1+r2)/r2 might still cause a (small) truncating/rounding error
