Hello,
For my project, I need to get values from different sensors, send it to a server using wifi of the esp8266, and go back to deep sleep until next wake up. My project will be powered by a battery (probably Li-ion 18650 3.7V). Right now, it's working fine but the esp is connected via the usb cable. I didn't integrate the deepsleep mode because I didn't have to. I'm working on that independently at the moment.
I first used the NodeMCU V3 but I realized I was not able to go lower than 10mA during deep sleep. I'm using now the esp8266 12F from Az-Delivery (D1 Mini Nodemcu with ESP8266-12F WLAN modules CH340G LUA – AZ-Delivery) and my current is lower than 1mA during deep sleep depending on the input voltage.
Sorry, I'm clearly not an expert but really interested to learn. If I understand correctly, I will have a minimum current (I hope 20-30uA) if I can provide a voltage of exactly 3.6V. Please correct me if I'm wrong. So since my input voltage will vary from 4.2V when the battery is full, up to 3V, I would have to use a regulator. I read a bit and watched a few videos but I would really appreciate to get some advice on which one would be the best choice (in terms of dropout voltage, quiescent current...) and how to integrate it into my project. Is there a better alternative for my project?
Thank you very much in advance for your help
Laurent
