voltage triggered PWM pin help
I need some help with programming. I want to start a FADE sequence when an analog pin sees voltage. Thank you for looking. :slight_smile:
Connect your LED with series resistor to pin 3.
When your voltage reaches a certain level, do an analogWrite in a "for" loop with the range you need.
