Hello guys, hope u coud help me with my job.
I need to analyze de voltage (pre-amplified) that comes from a balance to an analog input...
I have to create a measurament scale, i am thinking about taking the input voltage from the balance with 0 grams (empty) and with 1 kg on it, then scale it...
Wich is the method to have the best measument precision? Do you have better methods? Does anyone have tried to do something like this...
I hope i was clear to explain the problem, thanks in advance for helping!
Hi, your solution would work, however you are assuming a linear relationship.
You would produce a more accurate conversion by taking readings at 0, 100g, 200g, 300g and so on, this would let you check and calibrate with any non-linear characteristics.
TomGeorge:
Tom..
Hi Tom and thanks for the answer! You're right, i think i will also get smaller range measure to have more precision...
...But what do "linear relationship" and "non linear characteristics" mean? Thanks!
VALERiOSPQR:
It means that adding the same number of grams might not always add the same number of volts.
The word "linear" is in reference to a graph. If you draw a graph of the number of grams vs. the number of volts, will the graph be a perfectly straight line? If it is a straight line, then you have a "linear" relationship. If the graph is not a straight line, then it is not a linear relationship.
To discover this, it sounds like you will have to experiment.
