Volts x Resistance = A Thing?
Yes we did that at the very beginning
I know, I know . . . . ::slight_smile:
After splitting the atom we moved on to supernovas...
Hello,
Thanks for all the replies. So, the answer is that; Yes it is a thing, but its a bit quantum so nothing to worry about.
It seems I wrote the formula down wrong in the OP. Doing it correctly doesn't seem to make any difference to the result though, even with lots of decimal places. In a python console on the computer:
>>> Vin = 5.0
>>> R1 = 10000
>>> R2 = 510
>>> Vin * R2 / (R1 + R2)
0.24262607040913417
>>> (Vin * R2) / (R1 + R2)
0.24262607040913417
Karl.
karl101:
Hello,
>>> Vin = 5.0
>> R1 = 10000
>> R2 = 510
0.24262607040913417
0.24262607040913417
Karl.
That's cause PEMDAS to the rescue. Multiplications are performed before division anyway, and the parenthesis is redundant.
raschemmel:
He said the rain was probably more contaminated that the tap water. Any thoughts ?
Yes, I have one word for you:
Birds!
(Strictly speaking around here it isn't birds - it is bats! :astonished:
If you like, I can go take a picture of my car?)
It depends on how you define contamination. Tap water has all sorts of things added to it to kill bacteria.
Russell.
russellz:
Notably chlorine. Which might make it a trifle acidic - don't know if they make any attempt to neutralise it which would ipso facto, make it slightly salty.
100% safe for drinking of course, as it is no different from but vastly weaker than that in your stomach.
Paul__B:
Yes, safer for drinking but could be worse for some chemical processes. I believe it causes corrosion problems steam engine boilers for example.
Russell.
