So I read somewhere that you can control a buzzer sounds with a pot (so I'm guessing you can control it with the resistance).
Here: How to Vary the Volume of a Buzzer
So I had this idea, I am suppose to make an up/down binary counter application and I'm thinking about making a volume control application with a buzzer and said counter.
The idea is quite simple I have 15 levels max for the volume. I'm planning on using the code in arduino named fading.
This one
Fading
This example shows how to fade an LED using the analogWrite() function.
The circuit:
* LED attached from digital pin 9 to ground.
Created 1 Nov 2008
By David A. Mellis
modified 30 Aug 2011
By Tom Igoe
http://arduino.cc/en/Tutorial/Fading
This example code is in the public domain.
int ledPin = 9; // LED connected to digital pin 9
// nothing happens in setup
// fade in from min to max in increments of 5 points:
for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
// sets the value (range from 0 to 255):
analogWrite(ledPin, fadeValue);
// wait for 30 milliseconds to see the dimming effect
delay(30);
// fade out from max to min in increments of 5 points:
for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
delay(30);
except i change the LED with a buzzer will it still work? (I wonder)
as for the application of the up/down counter. I have my basic idea for it and I need to know if this code will work(If i exchange the LED with a buzzer).(I have no buzzer in hand right now and I will be able to acquire 1 next week but this experiment is due next week xD).
Will it work?
