Volume control of an external player
Hello,
I’ve done some googling and some forum digging here and it’s just taking too long to find out what I think should be quite straightforward.
I want arduino to read the amount of light in the room with a photoresistor (very basic), then map this to a specific range of numbers (1-1000 for example) (doable) and use this value to control the amplitude of an external audio signal (<-stuck).
For example raspberry is playing an mp3 on a loop. This is sent out from the line jack and then that amplitude would be controlled by arduino.
(I know raspberry has volume control inside and that it can be modulated via gpio, but theres only ~30 increments (in integers) of control, so that would not sound smooth, i believe.)
A digital pot is probably the solution. There are a couple of different types of digital interfaces so you can research and decide what you want to use. I believe they are usually 8-bits (256 steps).
…You know, you're going to be making a voltage divider (the photoresistor and another resistor) and you could just run the (line level) audio through that. You wouldn't get the full volume-range and it might not follow the "curve" you want, but it would be super-easy and cheap!
