Volume Control With Arduino
I am totally new.
I Want to control PC volume (like volume up/Down?mute) and also numeric 0 to 9, ( . ) [Dot], subtract, divide, multiply, add, RETURN.
All are ok...
But problem is, I don't know how to add the "Volume key" and "RETURN" key.
mine full code here, anyone can edit this?
In my code, RGB not mendetory.
> #include <Keyboard.h>
> #include <Adafruit_NeoPixel.h>
> #define ledCount 5                  //how many LEDs are there
> #define ledPin 21                   //which pin are they connected to
> int longPressDelay = 350;           //customizable keyboard values
> int spamSpeed = 15;
> byte inputs[] = {2,3,4,5,};          //declaring inputs and outputs
> #define inCount sizeof(inputs)/sizeof(inputs[0])
> byte outputs[] = {6,7,8,9,10};
> #define outCount sizeof(outputs)/sizeof(outputs[0])
> char layout[outCount][inCount] = {               //layout grid for characters (adjust if your grid is not 4x4)
>   {'VOL+',  'VOL-',  'MUTE',   'POWER_BUTTON'},
>   {'7',  '8',   '9',  '*'},
>   {'4',  '5',   '6',  '-'},
>   {'1',  '2',   '3',  '+'},
>   {'0',  '.',    '/',    'RENTER'},
> int keyDown[outCount][inCount];
> bool keyLong[outCount][inCount];
> Adafruit_NeoPixel strip = Adafruit_NeoPixel(ledCount, ledPin, NEO_GRB + NEO_KHZ800);
> void setup(){
>   for(int i=0; i<outCount; i++){    //declaring all the outputs and setting them high
>     pinMode(outputs[i],OUTPUT);
>     digitalWrite(outputs[i],HIGH);
>   for(int i=0; i<inCount; i++){     //declaring all the inputs and activating the internal pullup resistor
>     pinMode(inputs[i],INPUT_PULLUP);
>   Serial.begin(9600);               //establishing Serial link and initializing keyboard
>   Serial.println("Connected");
>   Keyboard.begin();
>   strip.begin();                    //initializing LEDs and setting them all to white
>   // put your initial LED color configuration here, e.g. this:
>   for (int i = 0; i<ledCount; i++){
>     strip.setPixelColor(i,50,50,50);
>   strip.show();
> //Main loop going through all the keys, then waiting 0.5ms
> void loop() {
>   for (int i=0; i<outCount; i++)
>     digitalWrite(outputs[i],LOW);   //setting one row low
>     delayMicroseconds(5);           //giving electronics time to settle down
>     for(int j=0; j<inCount; j++)
>       if(digitalRead(inputs[j]) == LOW)
>         keyPressed(i,j);            //calling keyPressed function if one of the inputs reads low
>       else if(keyDown[i][j] != 0)   //resetting the key if it is not pressed any more
>         resetKey(i,j);
>     delayMicroseconds(500);         //setting the row high and waiting 0.5ms until next cycle
> //if a key is pressed, this Funtion is called and outputs to serial the key location, it also sends the keystroke if not already done so
> void keyPressed(int row, int col){
>   Serial.print("Output: ");
>   Serial.print(row);
>   Serial.print(" Input: ");
>   Serial.print(col);
>   Serial.print(" ");
>   Serial.println(layout[row][col]);
>   if(keyDown[row][col]==0){         //if the function is called for the first time for this key
>     Keyboard.write(layout[row][col]);
>   else if(keyLong[row][col] && keyDown[row][col] > spamSpeed){ //if the key has been held long enough to warrant another keystroke set
>     keyDown[row][col] = 1;
>   else if(keyDown[row][col] > longPressDelay){ //if the key has been held for longer that longPressDelay, it switches into spam mode
>     keyLong[row][col] = true;
>   keyDown[row][col]++;
> void resetKey(int row, int col){ //resetting the variables after key is released
>   keyDown[row][col] = 0;
>   keyLong[row][col] = false;
Take a few moments to read the header posts on how to use the forum and post your code with tags .
Is this code copied from the internet ?
No, I suspect the forum has already corrupted the code you incorrectly posted. This happens when you do not use code tags. Please read the forum guide.
You cannot do that with the keyboard library. Did you search the forum for similar questions? I found this one very quickly.
If RETURN works OK, why do you need to add it?
yes, from youtube
OK, Thanks.
return key dose not work.
@PaulRB later, I found some code, I have to use (#include "HID-Project.h"), but all are they using rotary encoder. I want to use only button key.
@PaulRB bro, in my work, I need Numeric key, Enter key, ADD key, Substract key, multiply key, Divide key, ( . ) key and Volume key.
The library will work with either button keys or rotary encoder, you are not forced to use rotary encoder.
I will not be responding further to this topic until your first post is corrected.
