Hello everyone, I am trying to do the project with my
son that I share the link below.
Vorpal Hexapo
When I try to upload the gamepad code to arduino nano
"exit status 1
'Sd2Card' was not declared in this scope"
I shared the entire error I received in the text file, thank you in advance for your help.
Vorpal Error.txt (14.4 KB)
Please post the full error message
@ugurkiziloglu
Yours duplicate topic in "General Discussion" has been deleted
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
I'm new to the forum, I will pay attention to the topic you
mentioned. Thank you
TheMemberFormerlyKnownAsAWOL:
The error message is too long. I am adding some of it. Is
this enough?
C:\Users\admin\AppData\Local\Temp\Temp1_VorpalHexapod-master (2).zip\VorpalHexapod-master\Vorpal-Hexapod-Gamepad\Vorpal-Hexapod-Gamepad.ino:765:3: note: suggested alternative: 'clearCache'
clearFatDir(&card, &cache, fatStart, dataStart - fatStart);
clearCache
Vorpal-Hexapod-Gamepad:770:42: error: 'writeCache' cannot be used as a function
if (!writeCache(&card, &cache, fatStart)
Vorpal-Hexapod-Gamepad:771:55: error: 'writeCache' cannot be used as a function
|| !writeCache(&card, &cache, fatStart + fatSize)) {
exit status 1
Then copy it into a text file and attach it to a post
@UKHEliBob "Thank you for your help I did as you said.."
