Hi to all.
I´m trying to get together a project in which I need some user interface. I have a couple of Nokia monochrome displays but not big enough to show all the data and graphics I want.
On one of my shelves I found an old car stereo Jensen VM9312, I salvaged from it the display, is a very tempting 7" TFT. The video decoding chip is a VP77, and the TFT display is an A070FW03 V2. Before disassembling I tested the stereo, the display worked. Now iI have spent around a week trying to get it running but I can´t figure out from the datasheet which memory vectors I have to appoint or what do i have to send at least to know the display is alive.
I don´t even need to put real Video or VGS signals to it. Using the display´s built in OSD generation will be enough, well if i can upload graphics to the controller, THEN AWESOME. But no VGA nor CVBS needed.
I think probably there are a lot of VP77 enabled displays around, I´ve seen those in many portable DVD players. Maybe we could find a way to reuse them.
Thanks everyone.
PS: I´m using a Mega 2560 R3, I think in this case a Pro Mini could be used as well.
Hi to everyone!
Today i decided to put together the car stereo. Got connected to the SDA and SCK lines in attempt to "listen" to the traffic. None of methods worked using wire library. The addresses of the VP77 chip are 0x40, 0x42, 0xF4 and 0xF6. I guess that if i disconnect the data and clock lines and identify my arduino as any of those adresses i will be able to "listen" the incoming data from the board mcu?
Any suggestions?
Got lucky and captured all the indispensable I2C data to the display. Don´t have a library yet, just a sketch. Uploading soon pictures and sketch.
The sketch writes some junk lines using on chip osd, no implementation on print functions or advanced stuff. Initializations of gamma tables and font tables through i2c port. If you don´t need osd this at least initialize tft in RGB input mode, and you will be able to use it as a monitor.
This was running on aMega2560 r3 board, don´t forget to use the soft i2c library. for some reason native wire library doesn´t work. The flash library is because i dont get friendly yet with progmem.
Don´t crucify me please oh lovers of the pure code
this does the trick, is´nt that the most meaningfull.
VP77.ino (1.15 KB)
Functions.h (18.5 KB)
Tables.h (29.3 KB)
SoftI2CMaster-master.zip (16.1 KB)
Flash-5.zip (13.1 KB)
