I am seeking help transitioning from a flat file main.cpp (which worked fine) to a multi-file setup in VSC/PlatformIO. After two days of online research, failure, and fatigue, I have decided to post my files here to beg for help.
Below is the error message I receive on build, and below that are my files (two .cpp and a .h) Any help would be greatly appreciated.
THE ERROR MESSAGE
AppData\Local\Temp\cc6saFwQ.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0x2f4): undefined reference to `speedSetting'
<artificial>:(.text.startup+0x2f8): undefined reference to `speedSetting'
<artificial>:(.text.startup+0x2fc): undefined reference to `speedSetting'
<artificial>:(.text.startup+0x300): undefined reference to `speedSetting'
<artificial>:(.text.startup+0x4e8): undefined reference to `timeStamp'
<artificial>:(.text.startup+0x4ec): undefined reference to `timeStamp'
<artificial>:(.text.startup+0x4f0): undefined reference to `timeStamp'
<artificial>:(.text.startup+0x4f4): undefined reference to `timeStamp'
<artificial>:(.text.startup+0x516): undefined reference to `stallGuard'
<artificial>:(.text.startup+0x51a): undefined reference to `stallGuard'
<artificial>:(.text.startup+0x53a): undefined reference to `stallGuard'
<artificial>:(.text.startup+0x53e): undefined reference to `stallGuard'
<artificial>:(.text.startup+0x58c): undefined reference to `timeStamp'
<artificial>:(.text.startup+0x590): undefined reference to `timeStamp'
<artificial>:(.text.startup+0x594): undefined reference to `timeStamp'
<artificial>:(.text.startup+0x598): undefined reference to `timeStamp'
<artificial>:(.text.startup+0x59c): undefined reference to `speedSetting'
<artificial>:(.text.startup+0x5a0): undefined reference to `speedSetting'
<artificial>:(.text.startup+0x5a4): undefined reference to `speedSetting'
<artificial>:(.text.startup+0x5a8): undefined reference to `speedSetting'
collect2.exe: error: ld returned 1 exit status
*** [.pio\build\itsybitsy32u4_5V\firmware.elf] Error 1
// src/main.cpp
#include <TMCStepper.h>
#include <Arduino.h>
#include "BRINGUP.h"
TMC2209Stepper driver(&SERIAL_PORT, R_SENSE, DRIVER_ADDRESS);
speedSetting = 5500;
SERIAL_PORT.begin(115200); // INITIALIZE UART TMC2209
delay(10);
driver.begin(); // Initialize driver
driver.microsteps(8); // Set microsteps
pinMode(ENN_PIN, HIGH); // Activates all motor power internal to TMC2209
updateTerminal(driver);
driver.VACTUAL(speedSetting); // SET SPEED OF MOTOR
// include/BRINGUP.h
#pragma once
class TMC2209Stepper;
#define ENN_PIN 7 // Enable
#define SERIAL_PORT Serial1 // 328u HardwareSerial port pins 0 1
#define DRIVER_ADDRESS 0b00 // TMC2209 Driver address
#define R_SENSE 0.11f // Makerbase = 110milliOhm -- schematic says "0R11"
// prototypes
extern char16_t stallGuard;
extern long speedSetting;
extern long timeStamp;
void updateTerminal(TMC2209Stepper &driver);
// src/BRINGUP.cpp
void updateTerminal(TMC2209Stepper &driver) // displays stallguard every second
if (millis() - timeStamp >= 1000)
stallGuard = driver.SG_RESULT();
Serial.print(F("Stall: "));
Serial.print(stallGuard);
timeStamp = millis();
