VS1053 and arduino mega2560
Hello
I try to connect an vs1053 card with an arduino mega2560 and i have always the same error :
Couldn't find VS1053, do you have the right pins defined?
Or
Can't access SD card. Do not reformat. No card, wrong chip select pin, or SPI problem? SD errorCode: 0X20,0XFF
My connection :
| vs1053 | Mega | | - | - | | 5V | 5V | | GND | GND | | CS | 10 | | MISO | 50 | | MOSI | 51 | | SCK | 52 | | XCS | 7 | | XRESET | 9 | | XDCS | 8 | | DREQ | 3 |
Thank for your help
I finded the solution, I have a Arduino mega 2560 with a shield USB and i tried to connect a vs1053’s card.
I had always an error
Can’t access SD card. Do not reformat.
I resolved the error with this code :
// Chip select may be constant or RAM variable.
const uint8_t SD_CHIP_SELECT_PIN = 4;
pinMode(10, OUTPUT); // <— ADD THIS
digitalWrite(10, HIGH); // <<— ADD THIS
if (!sd.begin(SD_CHIP_SELECT_PIN)) {
sd.initErrorHalt();
I defined another pin for the pin 10 because it was use by the USB Shield.
Now it’s work
