VS1053 MP3 Codec
Hello, I recently bought a breakout board for the VS1053 MP3 Codec, I'm trying to test it but I seem to be failing. I used adafruit's code for it, it partially works. The codec itself is detected successfully, the SD card as well. But when it comes to playing a file from the card, I says "Playing track 001", after a minute or two (less than the track's length) it says "Done Playing" (indicates that the arduino isn't freezing) and nothing comes out the speakers. My SD card is 8 GB and due to it's size being largr than 2 GB, I can't format it to FAT16 so I'm stuck with FAT32. Although, the SD library can dump the file to the serial monitor. Please help me.
  This is an example for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
//#define CLK 13       // SPI Clock, shared with SD card
//#define MISO 12      // Input data, from VS1053/SD card
//#define MOSI 11      // Output data, to VS1053/SD card
// Connect CLK, MISO and MOSI to hardware SPI pins.
// See http://arduino.cc/en/Reference/SPI "Connections"
// These are the pins used for the breakout example
#define BREAKOUT_RESET  9      // VS1053 reset pin (output)
#define BREAKOUT_CS     10     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    8      // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
//#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
//#define SHIELD_CS     7      // VS1053 chip select pin (output)
//#define SHIELD_DCS    6      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 2       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
  // create breakout-example object!
  Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  // create shield-example object!
  //Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
uint8_t volume = 20;
  pinMode(A0,OUTPUT);
  pinMode(A4,OUTPUT);
  digitalWrite(A0,LOW);
  digitalWrite(A4,HIGH);
  Serial.println("Adafruit VS1053 Simple Test");
  if (! musicPlayer.begin()) { // initialise the music player
     Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
     while (1);
  Serial.println(F("VS1053 found"));
  SD.begin(CARDCS);    // initialise the SD card
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(volume,volume);
  // Timer interrupts are not suggested, better to use DREQ interrupt!
  //musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT); // timer int
  // If DREQ is on an interrupt pin (on uno, #2 or #3) we can do background
  // audio playing
  musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);  // DREQ int
  // Play one file, don't return until complete
  //Serial.println(F("Playing track 001"));
  //musicPlayer.playFullFile("track001.mp3");
  // Play another file in the background, REQUIRES interrupts!
  musicPlayer.startPlayingFile("track001.mp3");
  // File is playing in the background
  if (musicPlayer.stopped()) {
    Serial.println("Done playing music");
    while (1);
  if (Serial.available()) {
    char c = Serial.read();
    // if we get an 's' on the serial console, stop!
    if (c == 's') {
      musicPlayer.stopPlaying();
    // if we get an 'p' on the serial console, pause/unpause!
    if (c == 'p') {
      if (! musicPlayer.paused()) {
        Serial.println("Paused");
        musicPlayer.pausePlaying(true);
        Serial.println("Resumed");
        musicPlayer.pausePlaying(false);
  //volume = map(analogRead(A2),0,1023,0,255);
  //musicPlayer.setVolume(volume,volume);
  delay(100);
Hi
did you ever get to the bottom of this problem. I to have this problem and have no clue how to resolve it at this time ? :confused:
I know this problem is a year old, I will probably get pointed out for that. Being a Punk, I don't really give crap for their 'authority'.
So here is a project to give your VS10x3 a real test drive. Ed says it's for VS1053, But I got it working with VS1003, so I say VS10x3. It's actually pretty much the only serious MP3 project on the OPEN market. Here is the link.
Internet Radio + network MP3 player using VS1053
This project works. Hope you have fun
