VS1053B
My post was deleted for some unknown reason so I came here to give a try.
I got VS1053B MP3 player module (Picture bellow) and I was trying to find a simple working
example/pinout..etc but no luck, every link I found had no info at all about a basic setup, pinout or
code.
So if I may kindly ask if anyone of you got any link with an working simple useful example/library
that would be amazingly helpful.
Thanks in advance.
Best Regards,
Domino60
Hi there,
Check out this retired board from SparkFun. It has the same VLSI chip and 12.288MHz oscillator as your board seems to have, and it has similar looking SPI connections (the CS, SCLK, SI, and SO pins).
Check out the Documents section on that retired product page. It appears that there are some pretty decent code examples. I don't own any of these boards, so I am not able to test if the code will work the same for yours, but it's probably a good place to start.
Good luck!
