hi there - good day dear Arduino-friends
at the moment i have issus with the VSCode - i struggle alot!
btw: well - on the linux-notebook all goes well. There the Vscode runs perfect.
but i have VSCode installed on Win10 at the office - and here i added a bunch of stuff - like PlatformIO/Projects/ESP/.pio/build/esp32dev/ and stuff like that. And i guess that i have messed up my system somewhat.
i want to follow the manpages here: Python - Visual Studio Marketplace
but at the moment i guess that everything is messed up alot.
well i have looked after various options and things - but afaik i did not find out what goes wrong here.
guess that i have set up VScode wrong -
probably i have to throw away PlatformIO -
i guess that vscode waits to run and work with ESP32 (see below)
VSC normally runs a C++ Debugger: i guess that i have to tell VSCode that it will work with python.
> Executing task: C:\Users\Kasper\.platformio\penv\Scripts\pio.exe run <
Processing esp32dev (platform: espressif32; board: esp32dev; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32dev.html
PLATFORM: Espressif 32 (1.10.0) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 2.10003.190916 (1.0.3)
- tool-esptoolpy 1.20600.0 (2.6.0)
- toolchain-xtensa32 2.50200.80 (5.2.0)
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 26 compatible libraries
Scanning dependencies...
No dependencies
Building in release mode
Compiling .pio\build\esp32dev\src\main.cpp.o
Linking .pio\build\esp32dev\firmware.elf
Building .pio\build\esp32dev\firmware.bin
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [ ] 4.5% (used 14628 bytes from 327680 bytes)
Flash: [== ] 15.9% (used 208524 bytes from 1310720 bytes)
esptool.py v2.6
=========================================================================================================== [SUCCESS] Took 8.48 seconds ===========================================================================================================
Terminal will be reused by tasks, press any key to close it.
well i also have had a closer look at the manpages: Python - Visual Studio Marketplace
but at the moment i have no glue whats going on here.
any ideas smile - btw. should i
a. debug the system or
b. kill platform-io and all that stuff
dear friends i look forward to hear from you again
