Does anybody have any experience of using VST instrument plugins within an arduino to play midi instruments. I want to build a stand-alone midi player for a single VST instrument.
If you can make an Arduino to act as a USB device using midiUSB like you can on a 32u4 board as a micro or leonardo, it is all fairly straight forward. I should actually try this for myself, i have the parts.
No nobody has for the simple reason that you can’t run a VST instrument on any Arduino. Basically it does not have enough memory / speed / a display to control one / software to make use of one.
If you do want to see what is needed to write a VST host then this shows you how do do it. But this is for a Mac or windows not an Arduino.
How to make your own VST host
