Vu meter from mono to stereo
HI,
@0212995500229 code, thanks for posting, it helps the forum when an un-terminated thread causes problems
//STEREO LED VU
int led[11] = {4, 5, 6, 7, 8};         //Here you can set led pins for LEFT CHANNEL, add more pins for more LEDs, or remove for less
int rled[11] = {9, 10, 11, 12, 13};    //Here you can set led pins for RIGHT CHANNEL, add more pins for more LEDs, or remove for less
int input, l;
int rinput, r;
  for (l = 0; l < 11; l++)
    for (r = 0; r < 11; r++)
      pinMode(led[l], OUTPUT);
  pinMode(rled[l], OUTPUT);
  input = analogRead(A0);  //Here you can select analog pin for LEFT CHANNEL
  rinput = analogRead(A1); //Here you can select analog pin for RIGHT CHANNEL
  input = input / 12;      //You can change sensitivity FOR LEFT CHANNEL by changing divider (12)
  rinput = rinput / 12;    //You can change sensitivity FOR RIGHT CHANNEL by changing divider (12)
  if (input < 12)
    if (input == 0)
        digitalWrite(led[l], LOW);
      for (l = 0; l < input; l++)
        digitalWrite(led[l], HIGH);
        delay(4);
      for (l = l; l < 11; l++)
  if (rinput < 12)
    if (rinput == 0)
        digitalWrite(rled[r], LOW);
      for (r = 0; r < rinput; r++)
        digitalWrite(rled[r], HIGH);
        delay(4);
      for (r = r; r < 11; r++)
        digitalWrite(led[r], LOW);
Thanks… Tom… :slight_smile:
vu_LED_stereo.ino (1.49 KB)
I have some comments/queries about the code
Why are there 11 values allowed for in the LED pin arrays, but only 5 values ?
Why are these arrays of pin numbers declared as int when byte is plenty big enough ?
Why are these arrays not declared as const because their contents do not change in the program ?
Why aren’t the array names consistent and more explicit ? rightLedPins and leftLedPins would be preferable
Again, the variable names are are at best confusing, especially using lowercase l
Because the arrays are global the undefined entries between 5 and 10 will be set to zero so
will set pin 0 to OUTPUT for entries 5 to 10. As pin 0 is the Serial interface receive pin this is probably not a good idea.
Worse than that the pinMode() command is in a for loop inside a second for loop so will be executed 121 times
How many times, however, will
be executed ?
I stopped looking at that point because the “sins” of meaningless variable names and the obsession with 11 outputs per channel continues throughout the program
