Vu meter what is wrong
after so many days i found the solution, the problem is that MIDI.setHandleControlChange has not to be set in the ( void setup() ), because is automatically send the information to the correspond function. you need to set up the MIDI.setHandleControlChange in ( void loop() )
so when you press the button it choose the appropriate name and send the fanction.
  Serial.begin(115000);
  MIDI.turnThruOff();
  pinMode(inputPin, INPUT_PULLUP);
  //MIDI.setHandleControlChange(VUmeter_decks);
  // MIDI.setHandleControlChange(VUmeter_main);
  MIDI.read();
  currentState = digitalRead(inputPin);
  if (currentState != previousState & currentState == LOW) //button became pressed
  //  delay(50);
    state = !state;
  if (state == 0) {
  previousState = currentState;
