W-5100 shield-Arduino connection with the server failed
Hi
I'm using XAMPPserver in my PC to publish my arduino sensor data in a webpage. but unfortunately the answer of serial monitor is
connection failed
connection failed
if i use another port like 3306 the connection is succsesful but on port 80 is failed.
my apache is setted on port 80.
#include <SPI.h>
#include <Ethernet.h>
#include "DHT.h"
#define DHTPIN 9
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = {192, 168, 1, 18 }; //Enter the IP of ethernet shield
byte serv[] = {192, 168, 1, 5} ; //Enter the IPv4 address
EthernetClient cliente;
Serial.begin(9600); //setting the baud rate at 9600
Ethernet.begin(mac, ip);
dht.begin();
float hum = dht.readHumidity(); //Reading the humidity and storing in hum
float temp = dht.readTemperature(); //Reading the temperature as Celsius and storing in temp
float fah = dht.readTemperature(true); //reading the temperature in Fahrenheit
float heat_index = dht.computeHeatIndex(fah, hum); //Reading the heat index in Fahrenheit
float heat_indexC = dht.convertFtoC(heat_index); //Converting the heat index in Celsius
 if (cliente.connect(serv, 80)) { //Connecting at the IP address and port we saved before
Serial.println("connected");
cliente.print("GET /ethernet/data.php?"); //Connecting and Sending values to database
cliente.print("temperature=");
cliente.print(temp);
cliente.print("&humidity=");
cliente.print(hum);
cliente.print("&heat_index=");
cliente.println(heat_indexC);
//Printing the values on the serial monitor
Serial.print("Temperature= ");
Serial.println(temp);
Serial.print("Humidity= ");
Serial.println(hum);
Serial.print("Heat Index= ");
Serial.println(heat_indexC);
cliente.stop(); //Closing the connection
else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
delay(5000);
It doesn't have to be.
Your router (configuration) is blocking access to port 80. Reconfigure the router to allow it. Or, use a port that it doesn't block.
