W10, Error creating the sketch directory
Under Windows 10 I haven’t been capable of making it work. It takes a very, very, very long time to start and then complains and nothing can done. Here are some screen captures:
![image|581x212](upload://zb28KBy5Xq4BFi9T09GNYy7768d.png)
And, through PowerShell I have these:
PS C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit> & '.\Arduino IDE.exe'
Starting backend process. PID: 2836
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root WARN please install @theia/electron@1.12.0-next.1a1d7afc as a runtime dependency
root INFO Configuration directory URI: 'file:///c%3A/Users/jorov/.theia'
root INFO Theia app listening on http://localhost:59674.
root WARN The local plugin referenced by local-dir:/c%3A/Users/jorov/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/jorov/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\jorov\.arduinoProIDE\plugins does not exist.
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.1-beta.1" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Deploying backend plugin "cortex-debug@0.3.10" from "C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\cortex-debug\extension\dist\extension"
root INFO Deploying backend plugin "vscode-arduino-tools@0.0.1-beta.1" from "C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle"
root INFO Deploying backend plugin "cpp@1.52.1" from "C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\vscode-builtin-cpp\extension"
root INFO Deploying backend plugin "json@1.46.1" from "C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\vscode-builtin-json\extension"
root INFO Deploying backend plugin "json-language-features@1.46.1" from "C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain"
root INFO Deploy plugins list took: 1316.4 ms
root WARN Backend ConfigServiceImpl.onStart is slow, took: 1590.3 ms
daemon INFO Starting daemon from C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
daemon INFO Using config file: c:\Users\jorov\.arduinoIDE\arduino-cli.yaml
daemon INFO arduino-cli.exe version 0.18.1
daemon INFO Setting up Prometheus metrics on :9090/metrics
daemon INFO Starting daemon on TCP address 127.0.0.1:50051
daemon INFO Daemon is now listening on 127.0.0.1:50051...
daemon INFO Daemon is running.
root INFO Git askpass helper is listening on http://127.0.0.1:59681.
root WARN Frontend CommonFrontendContribution.configure is slow, took: 438.9 ms
root INFO Using Git [2.30.1.windows.1] from the PATH. (C:\Program Files\Git\cmd\git.exe)
root WARN Failed to resolve module: @types/body-parser
root WARN Failed to resolve module: @types/cookie
root WARN Failed to resolve module: @types/express
root WARN Failed to resolve module: @types/fs-extra
root WARN Failed to resolve module: @types/lodash.debounce
root WARN Failed to resolve module: @types/lodash.throttle
root WARN Failed to resolve module: @types/react
root WARN Failed to resolve module: @types/react-dom
root WARN Failed to resolve module: @types/react-virtualized
root WARN Failed to resolve module: @types/route-parser
root WARN Failed to resolve module: @types/safer-buffer
root WARN Failed to resolve module: @types/ws
root WARN Failed to resolve module: @types/yargs
root WARN Failed to resolve module: @theia/monaco
root WARN Failed to resolve module: @theia/editor
root WARN Failed to resolve module: @types/rimraf
root WARN Failed to resolve module: @types/tar-fs
root WARN Failed to resolve module: @types/uuid
root WARN Failed to resolve module: @theia/navigator
root WARN Failed to resolve module: @types/p-queue
root WARN Failed to resolve module: @theia/preferences
root WARN Failed to resolve module: @theia/electron
root WARN Failed to resolve module: @theia/keymaps
root WARN Failed to resolve module: @theia/messages
root WARN Failed to resolve module: @types/diff
root WARN Failed to resolve module: @types/dompurify
root WARN Failed to resolve module: @types/mime
root WARN Failed to resolve module: @types/request
root WARN Failed to resolve module: @types/dateformat
root WARN Failed to resolve module: @types/deepmerge
root WARN Failed to resolve module: @types/glob
root WARN Failed to resolve module: @types/google-protobuf
root WARN Failed to resolve module: @types/js-yaml
root WARN Failed to resolve module: @types/ncp
root WARN Failed to resolve module: @types/ps-tree
root WARN Failed to resolve module: @types/react-select
root WARN Failed to resolve module: @types/react-tabs
root WARN Failed to resolve module: @types/sinon
root WARN Failed to resolve module: @types/temp
root WARN Failed to resolve module: @types/which
root WARN Failed to resolve module: js-yaml
root WARN Failed to resolve module: temp
daemon INFO Checking signature [index: C:\Users\jorov\AppData\Local\Arduino15\package_index.json, signaturefile: C:\Users\jorov\AppData\Local\Arduino15\package_index.json.sig, trusted: true]
daemon INFO Checking if CLI is Bundled into the IDE
daemon INFO Loading hardware from: C:\Users\jorov\AppData\Local\Arduino15\packages
daemon INFO Loading package builtin from: C:\Users\jorov\AppData\Local\Arduino15\packages\builtin
daemon INFO Checking existence of 'tools' path: C:\Users\jorov\AppData\Local\Arduino15\packages\builtin\tools
daemon INFO Loading tools from dir: C:\Users\jorov\AppData\Local\Arduino15\packages\builtin\tools
daemon INFO Loaded tool [tool: Version: 5.8-arduino11]
daemon INFO Loaded tool [tool: Version: 1.2.1]
daemon INFO Adding libraries dir [dir: C:\Users\jorov\Documents\Arduino\libraries, location: user]
root WARN Frontend keybindings.onStart is slow, took: 258.6 ms
daemon INFO URL: https://downloads.arduino.cc/packages/package_index.json
daemon INFO Updating index [url: https://downloads.arduino.cc/packages/package_index.json]
root INFO Updating index: package_index.json completed.
root INFO Updating index: package_index.json.sig completed.
daemon INFO Checking signature [error: opening signature file: open C:\Users\jorov\AppData\Local\Temp\918371827.sig: El sistema no puede encontrar el archivo especificado., index: C:\Users\jorov\AppData\Local\Temp\918371827, signaturefile: C:\Users\jorov\AppData\Local\Temp\918371827.sig]
daemon INFO Updating libraries index
root INFO Updating index: library_index.json completed.
daemon INFO Error during sketch processing: Filesystem bottom is too deep (directory recursion or filesystem really deep): c:\Users\jorov\Documents\Arduino\BMP280_con_LCD_i2C\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h
daemon ERROR Error during sketch processing: Filesystem bottom is too deep (directory recursion or filesystem really deep): c:\Users\jorov\Documents\Arduino\BMP280_con_LCD_i2C\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h\BMP280_con_LCD_i2C.h
root ERROR Uncaught Exception:
root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 2 triggered by internal client error: read ECONNRESET
    at Object.callErrorFromStatus (C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\call.js:31:26)
    at Object.onReceiveStatus (C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:387:49)
    at Object.onReceiveStatus (C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:299:181)
    at C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@grpc\grpc-js\build\src\call-stream.js:145:78
    at processTicksAndRejections (internal/process/task_queues.js:76:11)
daemon INFO Daemon exited with exit code: 1.
root ERROR Request createNewSketch failed with error: 14 UNAVAILABLE: No connection established
root FATAL Failed to determine the sketch directory: Error: Request createNewSketch failed with message: 14 UNAVAILABLE: No connection established
root WARN Frontend EditorNavigationContribution.onStart is slow, took: 92133.6 ms
root INFO Board config changed:
root INFO Changed application state from 'init' to 'started_contributions'.
root INFO Checking whether '--no-optional-locks' can be used with the current Git executable. Minimum required version is '2.15.0'.
root INFO '--no-optional-locks' is a valid Git option for the current Git version: '2.30.1.windows.1'.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343] Sync of 5 plugins took: 402.4 ms
root ERROR Request search failed with error: 14 UNAVAILABLE: No connection established
root ERROR Request list failed with error: 14 UNAVAILABLE: No connection established
root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established
root ERROR Request searchBoards failed with error: 14 UNAVAILABLE: No connection established
root ERROR Request installed failed with error: 14 UNAVAILABLE: No connection established
root ERROR Request getContainerBoardPackage failed with error: 14 UNAVAILABLE: No connection established
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604) starting instance
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO <<< The layout has been successfully restored.
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][marus25.cortex-debug]: Loaded contributions.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.cpp]: Loaded contributions.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.json]: Loaded contributions.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.json-language-features]: Loaded contributions.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343] Load contributions of 5 plugins took: 199.3 ms
root WARN Frontend PluginViewRegistry.onDidInitializeLayout is slow, took: 204.1 ms
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): initializing(cortex-debug@0.3.10 with C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 12604] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): initializing(vscode-arduino-tools@0.0.1-beta.1 with C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): initializing(cpp@1.52.1 with C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): initializing(json@1.46.1 with C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): initializing(json-language-features@1.46.1 with C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO Changed application state from 'initialized_layout' to 'ready'.
root INFO [hosted-plugin: 12604] PLUGIN_HOST(12604): PluginManagerExtImpl/loadPlugin(C:\Users\jorov\Desktop\TEMP\Arduino20\arduino-ide_2.0.0-beta.5_Windows_64bit\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][marus25.cortex-debug]: Started plugin.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][arduino.vscode-arduino-tools]: Started plugin.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.cpp]: Started plugin.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.json]: Started plugin.
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343][vscode.json-language-features]: Started plugin.
root ERROR Request loadSketch failed with error: 14 UNAVAILABLE: No connection established
root ERROR Error: Request 'loadSketch' failed
    at Proxy.<anonymous> (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/bundle.js:64108:33)
    at ArduinoFrontendContribution.<anonymous> (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:3425:65)
    at step (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:3022:23)
    at Object.next (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:3003:53)
    at file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:2997:71
    at new Promise (<anonymous>)
    at push../node_modules/arduino-ide-extension/lib/browser/arduino-frontend-contribution.js.__awaiter (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:2993:12)
    at ArduinoFrontendContribution.push../node_modules/arduino-ide-extension/lib/browser/arduino-frontend-contribution.js.ArduinoFrontendContribution.openSketchFiles (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:3417:16)
    at ArduinoFrontendContribution.<anonymous> (file:///C:/Users/jorov/Desktop/TEMP/Arduino20/arduino-ide_2.0.0-beta.5_Windows_64bit/resources/app/lib/55.bundle.js:3376:26)
root INFO [df2d8c1d-fe56-46b6-9a8b-3611d4ddc343] Start of 5 plugins took: 1904.3 ms
root INFO Failed to start language server for arduino:avr:uno
monitor-service INFO >>> Disposing monitor service...
monitor-service INFO <<< Disposed monitor service.
Hope that helps.
2 posts were merged into an existing topic: Error creating the sketch directory
