HI members ,
I am new to arduino and learning day by day, i setup w25q memory and ds3231 memory module as per pin no . i want to save the time and date in flash memory whenever i send a variable in serial monitor , this is code -
type or paste code here
#include <SPI.h>
#include <Wire.h>
#include <DS3231.h>
DS3231 myRTC;
#define SPI_SPEED_HZ 800000
#define BLINK_INTERVAL 400
#define LED_PWR 13
int userVariable = 0; // User-defined variable
bool century = false;
bool h12Flag;
bool pmFlag;
const int CS_PIN = 7; // Chip Select pin for the W25Q64Mb flash module
while (!Serial);
SPI.begin();
pinMode(CS_PIN, OUTPUT);
digitalWrite(CS_PIN, HIGH); // Deselect the flash module initially
Wire.begin();
// Set the initial date and time in the RTC module
myRTC.setYear(24); // Set the year (e.g., 2021)
myRTC.setMonth(04); // Set the month (e.g., September)
myRTC.setDate(15); // Set the day (e.g., 15th)
myRTC.setHour(20); // Set the hour (e.g., 12 PM)
myRTC.setMinute(0); // Set the minute
myRTC.setSecond(0); // Set the second
// Display the initial date and time set in the RTC module
Serial.print("Initial Date and Time: ");
Serial.print(myRTC.getYear(), DEC);
Serial.print("-");
Serial.print(myRTC.getMonth(century), DEC);
Serial.print("-");
Serial.print(myRTC.getDate(), DEC);
Serial.print(" ");
Serial.print(myRTC.getHour(h12Flag, pmFlag), DEC); // 24-hr
Serial.print(":");
Serial.print(myRTC.getMinute(), DEC);
Serial.print(":");
Serial.println(myRTC.getSecond(), DEC);
void writeTimeToFlash(int year, int month, int day, int hour, int minute, int second) {
digitalWrite(CS_PIN, LOW); // Select the flash module
// Write the current time and date data to the flash memory
SPI.transfer(year);
SPI.transfer(month);
SPI.transfer(day);
SPI.transfer(hour);
SPI.transfer(minute);
SPI.transfer(second);
if (Serial.available() > 0) {
int userVariable = Serial.parseInt();
DateTime now = myRTC.getDate();
// Display the variable sending time
Serial.print("Variable ");
Serial.print(userVariable);
Serial.print(" sent at: ");
Serial.print(now.year(), DEC);
Serial.print("-");
Serial.print("-");
Serial.print(now.day(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.println(now.second(), DEC);
if (userVariable == 85) {
// Update the current time in the RTC module
myRTC.setHour(now.hour());
myRTC.setMinute(now.minute());
myRTC.setSecond(now.second());
writeTimeToFlash(now.year(), now.month(), now.day(), now.hour(), now.minute(), now.second());
Serial.println("Current time and date written to flash memory.");
output of my code is -
Initial Date and Time: 24-4-15 20:0:0
Variable 85 sent at: 2106-9-7 6:28:31
Variable 0 sent at: 2106-9-7 6:28:31
what is happening , i am unable to store time and date , why its shows 2106? help appreciated..
