W5100 and W5500
hello !!!
I have Ethernet Shield 2 R3 and Leonardo .
I'm working with the SNMP trap and request ....
In the SNMP , i have lenght message > 120 bytes .
The UDP2.h is limited 24 . I'm modify the value To 512 ( UDP2.h ).
Now i have the request send at 100 bytes .
I need only 4 sockets .
Have you got a idea for up the buffer to send > 300 bytes ??
Thank a lot !!!
Excuse for my english .... I'm french ... lol
I just tested a 250 byte UDP packet on my w5100 and it works ok. I'm using the WIZnet library.
edit: I'm testing on a Mega2560/ethernet shield.
thank for you reply .
I'm on Ethernet 2 and UDP 2
AFAIK, the hardware is capable of sending up to 1400 bytes per UDP packet. The limitation would be the library or the Arduino's SRAM.
hello
I have not enough memory in Leonardo for this application ... I have bug in my personal Lib .
BER in SNMP ( 7 bits not 8 bits ) .
Thank a lot
