W5100 cant connect to my modem
Hi, i have a arduino mega and a w5100 ethernetshield, after resetting the modem i can get on the server using 4g on my phone. When i power down arduino for a couple of minutes and then start it up again it wont let me connect with the ethernetshield shield anymore. Only lokal network is eble to connect, 4g dont.
The time for my ip which start with 213 is taking to long to respond, that is what google chrome is telling me.
After rebooting the modem i can connect with 4g again...
How to solve this?
Code: [Select]
//zoomkat 1-10-11
//web LED code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84/ when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0x22, 0x22, 0x34, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 0,25);
//byte gateway[] = {
  //192,168,0,1
byte gateway[] = {
  192,168,0,1
byte subnet[] = {
  255,255,255,0
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(903); //server port
String readString;
void setup(){
  pinMode(22, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("servertest1"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c); //uncomment to see in serial monitor
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString);
          //now output HTML data header
          client.println("Content-Type: text/html");
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>HTML form GET example</H1>");
          client.println("<FORM ACTION=\"http://213.**.**.**:903\" method=get >");
          client.println("Pin 4 \"on\" or \"off\": <INPUT TYPE=TEXT NAME=\"LED\" VALUE=\"\" SIZE=\"25\" MAXLENGTH=\"50\">
          client.println("<INPUT TYPE=SUBMIT NAME=\"submit\" VALUE=\"Change Pin 4!\">");
          client.println("</FORM>");
          client.println("
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          if(readString.indexOf("1005") >0)//checks for on
            digitalWrite(22, HIGH);    // set pin 4 high
            Serial.println("Led On");
          if(readString.indexOf("10051990") >0)//checks for off
            digitalWrite(22, LOW);    // set pin 4 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
Stop spamming.
Your previous post is still there. W5100 ethernet connection problems to 4G - Networking, Protocols, and Devices - Arduino Forum
Nobody ?
