I'm trying to supply power to my project using this breakout board W5100 and a PoE injector.
The board have PoE+ and PoE- pin directly connected on ethernet pin 8 and 7 but when I provide power through the ethernet cable, there isn't any power on PoE+ and PoE-.
@bask185: You need a PoE injector between the router and the ethernet shield. If that is what you mean, then yes, you are good to go. Insure the PoE injector is a passive unit. Active PoE injectors use the data lines also. That would be bad for your ethernet shield.
Without the PoE+ connected to pins 4 and 5, you will get no power. Pins 7 and 8 are both ground. And that is not taking into account the circuit board may have pins 4 and 5 grounded. That would be really bad for your power supply and PoE injector.
@SurferTim, thank you. Though I made a whole topic out for me problem, I didnt get 1 single usefull response. And now I finally know why I have no power. Tnx, really tnx alot
Thanks you for your clear answer
I'll try to hack this module, changing the RJ45 connector with one that doesn't have 4, 5 grounded.
I'm the guy who wrote that blog post... amusingly I find myself back here after random google searches years later.
I still didn't get it working.
Also, @SurferTim says about hacking the CAT5 cable, I already did that.
If I recall correctly I checked the schematic for the magjack and the one used in the W5100 red board doesn't appear to support PoE. (My understanding may be incorrect on that one as I don't know much about how magjacks work, other than they are black magic ways of interference avoidance, and they don't simply pass the connections from the CAT5 cable right through to the W5100 chip!)
Given the above, I'm now planning on finding a way to incorporate the W5100 circuitry onto my own board that does other things, thus saving space and allowing for PoE. I'll try to remember to feed back here if / when I manage that.
