W5100 module with Mega
I am working on some project which includes TFT screen shield and internet connection. The reason i needed Mega in the first place. I have problem to make W5100 module to work on Mega. Module is this one. My wiring is:
V+5 - 5V
NSS - 53
MO - 51
GND - nc
POE- - nc
GND - GND
RST - nc
SCK - 52
MI - 50
POE+ - nc
I tried standard ethernet library examples and haven't make it to work. I tried, say, WebServer example and get server is 0.0.0.0. I tried to change CS on w5100.h, line15 to 53 but get the same. I leave it as is and add:
pinMode(53,OUTPUT);
digitalWrite(53,HIGH);
and get the same.
Any suggestions what to do? Some link to a working solution would be nice.
who_took_my_nick:
That would have been the first step before buying not after.
Thank you very much!
You helped a lot.
Thank you for your reply.
Problem is that i have a tft shield attached on Mega, which covers all the pins. I will try it, of course.
Tried to connect RST to RESET. I couldn't upload sketch to the board. I uploaded it without RST connection and add it after but still don't work.
The standard w5100 library counts on the slave select connected to D10. Try that.
I can't because of tft shield. It is 3,97".
How come there is no example on internet with W5100 module and Mega? Working example....
who_took_my_nick:
All examples apply to the w5100 module if the pins are correct. If you can't use D10 as the w5100 slave select, then you have a problem. I have modified the w5100 library code to change the SS pin, but it isn't easy, and sometimes is not portable to newer versions of the ethernet library.
