Hello,
I've a tricky problem. I've an "arudino nano esp32 without headers" and a W5500 ethernet modul .
The problem is, that it only works, if I connect my pc via USB-C to the USB-C port on the arduino.
With this, it worked fine, the arduino answers on requests.
If I put an USB charger with a cable on the arduino USB-C port or if I use VIN with the USB charger or with my pc usb-c cable, the programm did not longer work correctly. I've got no http anser back from the arduino.
My arduino code looks like this:
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Wire.h>
#include <Adafruit_SGP30.h>
#include <Adafruit_HTU21DF.h>
#define audioDigs (30)
const int ledPin = A1;
//PIN definition
//Audio PIN
const int audioPin = A3;
//Hallsensor
const int hallSensorPinD = D9; // Digital pin connected to the KY-024 Hall sensors
const int hallSensorPinA = A2; // Analog pin connected to the KY-024 Hall sensors
//handle LED
unsigned long ledPreviousMillis = 0; // speichert den letzten Zeitpunkt, an dem die LED umgeschaltet wurde
unsigned long ledCurrentMillis = 0;
unsigned long ledOnMillis = 0; // speichert den Zeitpunkt, an dem die LED eingeschaltet wurde
const long ledBlinkInterval = 10000; // Intervallzeit in Millisekunden (5000 ms = 5 Sekunden)
const long ledOnTime = 100; // Zeit, die die LED eingeschaltet bleibt (100 ms)
bool ledState = LOW; // aktueller Zustand der LED
// Ethernet settings
byte mac[] = { 0xAA, 0xAB, 0xAC, 0x01, 0x02, 0x10 };
IPAddress ip(192, 168, 1, 249);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress dns(192, 168, 1, 16);
IPAddress targetIp(147, 54, 28, 65);
unsigned int targetPort = 80;
unsigned long ethAktivMillis = 0;
bool ethTimedout = false;
// Create instances for the sensors
Adafruit_SGP30 sgp;
Adafruit_HTU21DF htu = Adafruit_HTU21DF();
// Create a web server on port 80
EthernetServer server(8080);
EthernetClient client;
//SGP30-Counter for baseline
int sgp30Counter = 0;
bool isHumidity = false;
bool isAudio = true;
bool isAirquality = false;
bool isHall = true;
bool isFirstTime = true; //nur beim ersten Mal
//neu
pinMode(hallSensorPinD, INPUT);
pinMode(hallSensorPinA, INPUT);
pinMode(audioPin, INPUT);
pinMode(ledPin, OUTPUT);
Wire.begin();
delay(2000);
delay(2000);
//Setup pins
Ethernet.init(10);
// Ethernet.begin(mac);
delay(2000);
Ethernet.begin(mac, ip,dns,gateway,subnet);
// Ethernet.setSubnetMask(subnet);
// delay(500);
// Ethernet.setGatewayIP(gateway);
delay(2000);
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
while (true) {
delay(1);
delay(2000);
isFirstTime = true;
//Setup pins
digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level)
delay(300); // wait for a second
digitalWrite(ledPin, LOW); // turn the LED on (HIGH is the voltage level)
if (!sgp.begin()) {
isAirquality = true;
if (!htu.begin()) {
isHumidity = false;
isHumidity = true;
// Senden eines ARP-Requests
//sendArpRequest();
// // Start the server
delay(1000); // wait for a second
ledCurrentMillis = millis(); // aktuelle Zeit in Millisekunden
// prüft, ob das Intervall vergangen ist und die LED ausgeschaltet ist
if (ledCurrentMillis - ledPreviousMillis >= ledBlinkInterval && ledState == LOW) {
ledPreviousMillis = ledCurrentMillis; // speichert den aktuellen Zeitpunkt
ledOnMillis = ledCurrentMillis; // speichert den Zeitpunkt, an dem die LED eingeschaltet wurde
ledState = HIGH; // setzt den Zustand der LED auf HIGH
digitalWrite(ledPin, ledState); // schaltet die LED ein
// prüft, ob die LED lange genug an war
if (ledState == HIGH && ledCurrentMillis - ledOnMillis >= ledOnTime) {
ledState = LOW; // setzt den Zustand der LED auf LOW
digitalWrite(ledPin, ledState); // schaltet die LED aus
// ethAktivMillis = millis();
if (isFirstTime) {
isFirstTime = false;
delay(500); // wait for a second
// Make a GET request to the server
if (client.connect(targetIp, targetPort)) {
client.println("GET /api/ping HTTP/1.1");
client.println("Host: 1.1.1.1");
client.println("Connection: close");
client.println();
// Wait for the response
while (client.connected()) {
if (client.available()) {
char c = client.read();
// Ensure the connection is fully closed
client.stop();
delay(1000); // Add a delay to ensure the connection is fully closed
delay(2000);
server.begin();
delay(2000);
EthernetClient serverClient = server.available();
if (serverClient) {
serverClient.setConnectionTimeout(400);
// Wait for a client to connect
String currentLine = "";
String request = "";
while (serverClient.connected()) {
// while (client.connected() && !ethTimedout) {
if (serverClient.available()) {
String request = serverClient.readStringUntil('\r');
serverClient.flush();
if (request.indexOf("GET /api/v1/temperature") >= 0) {
serverClient.println("HTTP/1.1 200 OK");
serverClient.println("Content-Type: text/plain");
serverClient.println("Connection: close");
serverClient.println();
serverClient.println(handleTemperature());
} else if (request.indexOf("GET /api/v1/humidity") >= 0) {
serverClient.println(handleHumidity());
} else if (request.indexOf("GET /api/v1/tvoc") >= 0) {
serverClient.println(handleTVOCECO2());
} else if (request.indexOf("GET /api/v1/eco2") >= 0) {
} else if (request.indexOf("GET /api/v1/airquality") >= 0) {
} else if (request.indexOf("GET /api/v1/audio") >= 0) {
serverClient.println(handleAudio());
} else if (request.indexOf("GET /api/v1/hall") >= 0) {
serverClient.println(handleHallSensor());
} else if (request.indexOf("GET /api/v1/status") >= 0) {
serverClient.println(handleStatus());
} else if (request.indexOf("GET /api/v1/ping") >= 0) {
serverClient.println(handlePing());
// Handle other requests
serverClient.println("HTTP/1.1 404 Not Found");
serverClient.println("Not Found");
// if (millis() - ethAktivMillis >= 10000) {
// ethTimedout = true;
serverClient.stop();
delay(100); // wait for a second
digitalWrite(ledPin, LOW); // turn the LED off by making the voltage LOW
delay(10);
String handleStatus() {
String response = "{\"Airquality\":" + String(isAirquality) + ",\"radiation\":" + String(isHall) + ",\"audio\":" + String(isAudio) + ",\"temperature_humidity\":" + String(isHumidity) + "}";
return response;
String handleTemperature() {
String response = "";
if (isHumidity) {
float temperature = htu.readTemperature();
response = "{\"temperature\": " + String(temperature) + "}";
return response;
String handleHumidity() {
if (isHumidity) {
float humidity = htu.readHumidity();
response = "{\"humidity\": " + String(humidity) + "}";
return response;
String handleTVOCECO2() {
if (isAirquality) {
if (!sgp.IAQmeasure()) {
return "";
response = "{\"tvoc\": " + String(sgp.TVOC) + "\"ec02\": " + String(sgp.eCO2);
if (!sgp.IAQmeasureRaw()) {
return response + "}";
response = response + "\"RawH2\": " + String(sgp.rawH2) + ",\"rawEthanol\": " + String(sgp.rawEthanol);
uint16_t TVOC_base, eCO2_base;
if (!sgp.getIAQBaseline(&eCO2_base, &TVOC_base)) {
response = response + "\"\eCO2_base\": " + String(eCO2_base) + "\"TVOC_base\": " + String(TVOC_base);
return "";
String handleAudio() {
if (isAudio) {
int audioAverage = 0, audioMax = 0, audioMin = 1024;
int audioInRectified;
int audioInRaw;
String response;
for (int i = 0; i < audioDigs; i++) {
audioInRaw = analogRead(audioPin);
audioInRectified = abs(audioInRaw - 337); // level shift for 3,3V
audioMin = min(audioMin, audioInRaw);
audioMax = max(audioMax, audioInRaw);
audioAverage += audioInRaw;
audioAverage /= audioDigs;
response = "{\"audio\": " + String(audioAverage) + ",\"audioInRectified\": " + String(audioInRectified) + ",\"audioMin\": " + String(audioMin) + ",\"audioMax\": " + String(audioMax) + ",\"audioAverage\": " + String(audioAverage) + ",\"audioPeakToPeak\": " + String(audioMax - audioMin) + "}";
return response;
return "";
String handleHallSensor() {
if (isHall) {
int sensorValue = analogRead(hallSensorPinA); // Read the hall sensor value
int sensorTriggered = digitalRead(hallSensorPinD); // Read the hall sensor value
int trueFalse = 0;
if (sensorTriggered == 1) {
trueFalse = 1;
String response = "{\"value\": " + String(sensorValue) + ",\"trigger\": " + String(trueFalse) + "}"; // Create a JSON response
return response;
return "";
String handlePing() {
String response = "{\"ping\": " + String("Hello World") + "}";
return response;
I've also written a simple code where only the W5500 shield is used and no other components (like sgp30, ...) to work as a rest server. But the same behaviour. With pc connected, it worked fine, without not.
#include <SPI.h>
Ethernet.init(10);
delay(2000);
Ethernet.begin(mac, ip, dns, gateway, subnet);
delay(2000);
while (true) {
delay(1);
server.begin();
delay(2000);
if (serverClient) {
Serial.println(request);
return response;
