I am using W5500 with arduino Mega to interface to a device.
The device acts as a TCP client and connects to the TCP server which is the Mega board.
The device sends a keepalive timer in one of the messages based on which the Server needs to periodically send some data.
The code that I have written works fine till the session is maintained. But when the device breaks the connection sometimes and tries to re-establish,
then no data is sent from the server to the device.
I am checking the client in the following way:
tempC = g_server.available();
if (tempC) {
client = tempC;
I am doing this so that, when there is no data from the client to the server, the server keeps on sending periodic data to the client which was connected previously
But, if the client disconnects and connects with different port id, then the server should send data to new client.
But, this particular thing is not happening.
Can anyone suggest some reason?
void OPENAMIP()
static uint32_t lastTime = 0;
// byte CS=0;
char *ret = NULL;
static boolean recvInProgress = false;
static byte ndx = 255;
char endMarker = END_MARKER_OPENAMIP;
char rc = 0;
if (tempC) {
client = tempC;
if (client) {
while (client.available() > 0 && g_TCPPktTransferComplete == false) {
rc = client.read();
// Serial.write(rc);
if (recvInProgress == true) {
if ((rc == endMarker) or (ndx >= MAXPACKETSIZE_OPENAMIP - 1)) //either end of packet reached or buffer overflow
g_receivedCharsfromMODEM[ndx] = '\0'; // terminate the string
ndx = 255;
g_TCPPktTransferComplete = true;
else {
g_receivedCharsfromMODEM[ndx] = rc;
if (rc == 'F') {
client.write(g_STATUS_OPENAMIP); // need to get the status from control card before this based to ack lock status
client.write(CR);
client.write(NL);
ndx++;
else if (ndx == 255) {
recvInProgress = true;
g_modemDataReady = false;
ndx = 0;
ndx++;
if ((alive_flag_updated) && (millis() - lastTime > ((g_openamip_alive_interval - 1) * 1000))) { //keep alive
lastTime = millis();
client.write(g_header);
client.write(g_latSign);
client.write(g_LAT);
client.write(space);
client.write(g_longSign);
client.write(g_LONG);
client.write(footer);
client.write(CR);
client.write(NL);
if (g_TCPPktTransferComplete == true) {
ret = strstr(g_receivedCharsfromMODEM, ALIVE_INTERVAL_MSG);
if (ret != NULL) {
ret = strtok(ret, " ");
ret = strtok(NULL, "\r");
g_openamip_alive_interval = atoi(ret);
alive_flag_updated = true;
client.write("a 2");
client.write(CR);
client.write(NL);
Serial.print("CLIENT: ");
Serial.println(client.remoteIP());
ret = strstr(g_receivedCharsfromMODEM, WHERE_MSG);
if (ret != NULL) {
g_openamip_where_interval = ret[0] - '0';
client.write(CR);
client.write(NL);
g_modemDataReady = true;
g_TCPPktTransferComplete = false;
This is the main function which calls the OPENAMIP() function continously
int main (void)
//initialisation related tasks
init_all_peripherals ();
/************* Setup the interrupts for Buttons *******************/
pinMode (ACQUIRE_PIN, INPUT_PULLUP);
attachInterrupt (digitalPinToInterrupt(ACQUIRE_PIN), acquire, FALLING); //ACQUIRE_PIN is 4 for INT.4
pinMode (STOW_PIN, INPUT_PULLUP);
attachInterrupt (digitalPinToInterrupt(STOW_PIN), stow, FALLING); //A
while (1)
//receive data from 3 sensors WITHOUT BLOCKING and no delay
//send data to CC if data acquisition complete
acquire_action();
stow_action();
receiveDataFromGPS();
processAndSendGPSData();
receiveDataFromInclinometer();
processAndSendInclinometerData ();
receiveDataFromCompass();
processAndSendCompassData();
receiveDataFromCC();
processDatafromCC();
OPENAMIP();
receiveBUCData();
processBUCData();
sendNewBUCparamteresToCC();
return 0;
