[-Waggressive-loop-optimizations] compile error
I get this very strange compilation error: [-Waggressive-loop-optimizations]
All libraries used for this code are up to date and are being used, no doubles of these libraries anywhere.
It seems to point to a function called all2ZeroSpeed, and yes the speed is “Speeed”.
The code is in attachment (too large to include in `` )
Can you please give some pointers? Any help is very much appreciated.
The extended compilation output gives following lines in red:
C:\Users\Mysafety\Google Drive\documents\Arduino\David_Bodnar_handheld_DCC___throttle\David_Bodnar_handheld_DCC___throttle.ino: In function ‘all2ZeroSpeeed’:
C:\Users\Mysafety\Google Drive\documents\Arduino\David_Bodnar_handheld_DCC___throttle\David_Bodnar_handheld_DCC___throttle.ino:366:37: warning: iteration 4 invokes undefined behavior [-Waggressive-loop-optimizations]
** Serial.print(LocoAddress[tempx] );//locoID);**
C:\Users\Mysafety\Google Drive\documents\Arduino\David_Bodnar_handheld_DCC___throttle\David_Bodnar_handheld_DCC___throttle.ino:364:3: note: containing loop
** for (int tempx = 0; tempx <= maxLocos; tempx++) {**
David_Bodnar_handheld_DCC___throttle.ino (12.9 KB)
for (int tempx = 0; tempx <= maxLocosI can’t see your code, but from the error messages, that comparison looks a bit odd to me.
Hi AWOL,
this is the section of the code that the error refers to:
void all2ZeroSpeeed() {  // set flag to 1 to stop, set to 0 to restore
    Serial.print("<t1 ");
    Serial.print(" ");
    if (ZeroSpeedFlag == 1) {
      Serial.print(0);//LocoSpeed[0] );
    else Serial.print(LocoSpeed[0] );
    Serial.print(" ");
    Serial.print(LocoDirection[1] );
    Serial.write(">");
AWOL:
Hi AWOL, is there a mistake in that statement?
brice3010: Hi AWOL, is there a mistake in that statement?
Maybe, maybe not.
If I have six locos, I would expect maxLocos to have the value six, but I would not expect a for loop to count up to six, especially if I'm using tempx as an index into an array that has maxLocos elements.
From the ino
int maxLocos = 4;// number of loco addresses
int LocoAddress[4] = {1830, 3, 999, 4444};
Arrays run from 0. So your For loop should use < not <=
Which may or may not be the compilers problem.
Mark
I do apologise - the message (and the value of maxLocos) was there in the error messages iteration 4 invokes undefined behavior
SOLVED!!
That did it; thanks a lot AWOL and holmes4: you are geniuses!!
