Somewhere in my code I need to pause the program and wait for user input (serial). The input I'm getting from the user is a string. This is what I found on google for "wait for user input":
while (Serial.available() == 0) {}
Then I tried to combine with my get string for serial code:
while (Serial.available() > 0) {
input = Serial.read();
output += input;
But it doesn't work. When I write the string in serial input and press enter, the parent while statement becomes true immediately exiting the child while loop resulting in only 1 character retrieved. So my question is:
How can I pause the program, get user input to string and carry on?
// wait for input
while(Serial.avalable() ==0) { // do nothing }
// read input as long as data is available
while(Serial.available() > 0)
// read data here
What terminates the string? How do you KNOW when all the user input has arrived?
If you KNOW when the end of the input has arrived, you can wait for it:
char c = '';
while(c != endOfPacketMarker)
if(Serial.available() > 0)
c = Serial.read();
// Add c to the string, NOT a stupid String
If you don't know what terminates the user input, then you can't wait for it all to arrive, since you would have no way of knowing that it HAS all arrived. Then, you'd just have to wait for some time and hope...
UKHeliBob:
Read single characters and add them to a String (if you must !) until you receive a terminating character such as Carriage Return
I'm not sure how? Doesn't my string already have a null terminator when I initialize the variable?
sterretje:
// wait for input
// read data here
I tried this and didn't work
PaulS:
char c = '';
c = Serial.read();
This is the format I am looking for:
A string that contains 3 "values" separated with a delimiter. I thought of using string.length() but the values do not have a fixed length. It could be:
Where is the data coming from? If the user is entering the data in the Serial Monitor application, require them to set the line ending value to something other than none.
To get input from the Serial object via the monitor, try this simple test:
char input[20];
int charsRead;
if (Serial.available() > 0) {
charsRead = Serial.readBytesUntil('\n', input, sizeof(input) - 1); // Read chars from serial monitor
input[charsRead] = '\0'; // Terminate with null
Serial.println(input);
// Now figure out how to use the strtok() function
After you have grabbed the user input, study how to use strtok() to read the delimiters to break out the string.
Can we be clear whether you want to use a String (a String object created using the String library) or a C style string (a zero terminated array of chars) ?
In either case you need to decide how the program will know that user input is complete.
