I want to write a program where, I have a signal "B", when it goes LOW, the program waits. and when it is HIGH the program continues..
Can u help me guys...
That sounds like a while loop to me.
while (digitaRead(someInputPin) == LOW)
//do nothing
//now do something
However, I am suspicious of your description of the requirement since you called the input signal "B". Where is this signal coming from ?
you should post some code......
while(check_signal_b() == false){
// wait if function returns false or low
write a function to check the signal check_signal_b() and return a boolean value
Thank u guys
